Old 04-09-2008, 03:01 AM   #1 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
ElmScan + Customized Scantool Software = data logging!
Hello -
Last year I got one of these gizmos that interfaces the OBD-II to a PC :
ElmScan VPW Scan Tool - P/N: 420300
EDIT: URL BELOW IS DEAD LINK BECAUSE PRODUCT NO LONGER OFFERED
http://www.scantool.net/products/pro...products_id=12
The ElmScan VPW Scan Tool comes mounted in a steel enclosure and can be used with our free software to turn your computer into a sophisticated auto diagnostic system. This interface supports the J1850 VPW protocol used mostly in General Motors vehicles.
Now, it took me a (long) time to get it working right. My Laptop PC (probably) had too many apps running, so the Elmscan was having connection problems. Here is what I did :
1 - Bided my time and found an obsolete 2.5" 4GB hard disk for $10. This way, if I crash the disk proving the system, I don't care because the hard disk is worthless anyway. I have an easy-to-swap hard disk, so I can pop the "base OS" hard disk in, go to work, and swap my "regular OS" back in when I am done.
2 - Installed a base XP OS on the 4GB hard disk in my laptop. That way, there is no contention for the COM1 port.
3 - Downloaded the "scantool v1.13" software that comes with it. Since it comes with source code, I could customize it after ...
4 - ... I downloaded the "allegro" game programming library for Windows/XP :
Allegro - Download - Latest version (download all422.zip)
5 - Used my trusty Visual C++ version 6.0 to compile Allego. I procastinated doing this because I expected it to be a PITA. In fact it was easier than I thought. This is the power of gamer-programmers. They are edge and MAKE IT WORK! Pssst: But, you don't need to compile it. There are also pre-compiled binaries at the URL in Step 4. Stooopeed me did it the hard way.
6 - Once I had the library, I made a Visual C++ 6.0 project for the scantool software and customized it for my SW2 :
Still working on the color pallete, :
These are the only variables that are available for my Saturn :
4 - But the really big thing is that I got it to log data. I am logging in 1 second increments. I post-processed this to be one minute increments in this example result :
Code:
YYYMMDD,HHMMSS,Absolute Throttle Position (%):,Engine RPM:,Vehicle Speed (MPH):,Calculated Load Value (%):,Timing Advance (Cyl. #1) (?):,Intake Manifold Pressure (inHg):,Short Term Fuel Trim (Bank 1) (%):,Long Term Fuel Trim (Bank 1) (%):,Intake Air Temperature (? F):,Coolant Temperature (? F):,O2 Sensor 1/Bank 1 (V):,O2 Sensor 2/Bank 1 (V):
20080407,201137,13.367,2021.100,52.533,46.817,35.150,17.542,1.088,-7.000,71.900,170.133,0.518,0.721,
20080407,201242,8.130,1952.400,54.867,30.302,37.975,11.647,-0.082,-7.367,74.783,186.950,0.537,0.621,
20080407,201348,13.787,1964.333,55.350,48.922,36.117,19.197,0.623,-7.000,80.067,190.000,0.590,0.710,
20080407,201455,11.310,1886.717,53.233,39.983,39.208,15.507,1.322,-5.495,87.533,190.000,0.481,0.732,
20080407,201601,16.863,1900.667,53.817,53.895,27.317,21.542,-1.065,-2.300,95.667,190.000,0.389,0.638,
20080407,201709,13.510,1953.183,55.133,45.238,37.333,17.980,-0.237,-2.300,103.133,190.000,0.471,0.669,
20080407,201814,8.403,1908.133,53.733,29.813,41.208,12.020,-1.097,-3.200,105.000,190.000,0.354,0.671,
20080407,201919,8.272,1777.917,50.000,31.502,35.792,12.173,-0.502,-4.167,105.000,190.000,0.346,0.718,
20080407,202023,10.620,1863.317,52.800,38.110,39.350,14.567,0.650,-2.300,105.000,190.000,0.283,0.574,
20080407,202128,7.085,1562.167,52.383,35.080,30.592,14.065,2.123,-5.700,106.533,190.500,0.517,0.616,
20080407,202234,11.227,1724.267,49.000,42.093,32.433,15.575,0.395,-5.617,105.367,190.133,0.452,0.541,
20080407,202339,8.697,1782.100,50.017,36.640,35.825,14.210,1.973,-2.640,107.000,190.000,0.461,0.551,
20080407,202446,9.245,1394.267,44.483,41.762,25.108,16.237,0.217,-6.210,106.833,191.033,0.502,0.572,
20080407,202549,10.242,1607.800,50.583,41.063,30.183,16.167,2.068,-5.530,105.567,190.500,0.352,0.396,
20080407,202653,7.198,1347.733,42.583,33.838,23.225,13.590,0.687,-7.867,106.267,191.833,0.483,0.436,
20080407,202758,8.723,1548.133,43.383,39.198,30.417,15.017,-0.398,-5.953,109.467,190.133,0.606,0.500,
20080407,202901,10.207,1615.150,45.067,38.272,30.058,15.563,0.347,-3.800,111.000,190.000,0.407,0.405,
20080407,203003,10.637,1653.900,46.233,41.332,33.733,15.853,-0.970,-2.300,111.200,190.000,0.565,0.496,
20080407,203104,8.885,1590.700,44.533,38.265,33.633,15.340,0.365,-2.300,112.000,190.767,0.559,0.539,
20080407,203207,12.003,1580.317,48.100,42.422,23.208,16.358,0.420,-5.190,113.600,191.600,0.429,0.404,
20080407,203307,13.262,1574.500,48.517,44.165,23.692,17.822,0.033,-5.460,114.333,191.500,0.488,0.551,
20080407,203409,11.132,1537.083,48.250,42.305,24.108,17.785,1.690,-4.510,112.967,190.800,0.431,0.626,
20080407,203515,17.900,1854.267,52.183,55.985,24.950,23.225,-1.523,-2.300,112.800,192.000,0.459,0.630,
20080407,203622,16.592,1829.983,54.367,49.727,25.608,21.535,-0.722,-4.170,112.000,192.000,0.464,0.731,
20080407,203724,7.418,1364.150,41.400,34.622,22.500,15.088,1.102,-5.190,111.017,191.550,0.321,0.272,
20080407,203829,13.582,1543.383,46.683,46.947,21.217,19.203,-2.012,-6.230,111.533,192.083,0.474,0.498,
20080407,203934,8.992,1511.517,48.533,38.937,23.875,16.125,1.495,-7.893,111.733,192.000,0.522,0.300,
20080407,204037,6.512,1385.333,44.033,31.723,26.550,12.637,2.392,-6.220,110.500,190.667,0.499,0.524,
20080407,204148,4.633,1420.150,48.117,26.790,26.808,11.128,2.470,-8.820,108.467,190.867,0.561,0.520,
20080407,204253,5.087,1332.000,43.350,29.773,25.800,11.532,2.833,-9.665,105.033,190.333,0.484,0.562,
Using the original 1-second increment data, I used this to make a *simple* RPM vs MPH chart that shows my engine on coasting :
My long term goals are :
1 - Testing only. The Scangauge is still my main man. At this point, I want to see the behavior of mods like my EFIE, the IAT resistor mod, and maybe some aero mods. I wanted this gizmo because I couldn't see the fuel trim or the 02 sensor with my ScanGauge I. Also, no data logging with the ScanGauge.
2 - Get a solid state hard disk. I can get a 2GB hard disk for $60 right now. If I run the 4GB until it crashes, the price will be lower by then.
3 - Define an algorithm that uses the data I am collecting to display real time MPG (Help Me Please !!!!!!).
CarloSW2
American Solar Energy Society
Old 04-09-2008, 08:17 AM   #2 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
CarloSW2
I've been chewing on that one a little too since my elm323 showed up. Here's all I've got so far:
PID 07 -> xx Long term fuel trim Bank 1 % x*(100.0/128)-100
PID 0b -> xx Intake Manifold Pressure kPaA x
PID 0c -> xx xx Engine RPM RPM x*0.25
PID 0d -> xx Vehicle Speed km/h x
PID 0f -> xx Intake Air Temperature C X-40
lastScanTime=now (milliseconds)
onScanEvent{
time=now-lastScanTime
lastScanTime=now
distance=speed(pid0d) * time
"airMoles"=some PV=NRT thing, http://en.wikipedia.org/wiki/Ideal_gas_law
* V=rpm(pid0c)*displacement*volumetric efficiency, P=pid0b, T=Pid0f
oxygen=airMoles* 20% ?
stiochfuel=oxygen/14.7
fuel=stoichfuel*fuelTrim(pid07)
litersPer100KM= fuel converted to liters/distance converted to km
MilesPerGallon= distance converted to miles/fuel converted to gallons
ref: http://prj.perquin.com/obdii/
ref: http://en.wikipedia.org/wiki/Ideal_gas_law
Old 04-09-2008, 09:43 PM   #3 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
dcb -
*Arf*, that's really hard. Time to do more homework.
CarloSW2
Old 04-10-2008, 09:08 AM   #4 (permalink)
dcb
needs more cowbell
dcb's Avatar
Sorry. Try out the opengauge freeduino signal processor then. Let us know if it works
(then teach it to read your cruise control switches on an analog port)
Old 04-10-2008, 06:43 PM   #5 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
dcb -
That's ok. Actually, I see *some* of these calculations already in the scantool source code, so it is definitely speaking the same language. I guess that's another reason why the ScanGauge is so cool. I'll need to read your "opengauge development: gunio technical considerations" thread also.
CarloSW2
Old 04-11-2008, 12:52 AM   #6 (permalink)
dcb
needs more cowbell
dcb's Avatar
The guino isn't going to help too much with an obd mpg effort. The guino/opengauge efforts currently look directly at the injector and the speed sensor, and bypass all the obd business. It is much easier to record how long the injector has been open than it is to get mpg out of an obd port, excepting that you have to tap some wires.
Old 09-02-2008, 09:57 PM   #7 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
Hello -
I noticed this commercial program from Australia. It is designed to work with the ElmScan hardware. It also claims to be able to deduce instant-MPG from OBD II data, which is what I have been looking for :
OBD 2007 - Installation Guide
http://www.glmsoftware.com/Documenta...de20080822.pdf
Fuel Analysis (Page 15 of PDF)
Even though there is no specific pid for fuel consumption in the OBDII specification, fuel consumption can be calculated, if a vehicle supports Pid 0x0D Vehicle Speed and Pid 0x10 Mass Air Flow. All vehicles support vehicle speed and nearly all vehicles support MAF.
MAF, the mass of air moving into the engine is measured in grams per second. A petrol/gasoline engine burns the air/fuel mixture at the stoichiometric air fuel ratio of 14.64:1. The oxygen sensors in a modern vehicle are designed in conjunction with both the short and long term fuel trims to maintain this ratio. Under ideal conditions for every 14.64 grams of air an engine will consume 1 gram of petrol. We can therefore calculate FuelFlowGramsPersSec = MAF/Air Fuel ratio. We can convert the previous figure to FuelFlowLitresPerSecond by dividing FuelFlowGramsPerSec by the density of petrol/gasoline.
We can then readily convert that figure to FuelFlowLitresPerHour -- i.e. litres/hour. Fuel consumption is then simply SpeedKmsPerHour/FuelFlowLitresPerHours -- i.e. litres/kms. All the remaining figures on the OBD 2007 Fuel Analysis tab are returned by simple conversion factors -- for Metric, Imperial (US) and Imperial (UK) units.
Late model vehicles which use Oxygen sensors known as wide range linear Oxygen sensors, can also introduce another Pid 0x44, Commanded Equivalence Ratio. This pid allows fine adjustment of air fuel ratio from the constant 14.64 by modifying the air fuel ratio by a value between 0 and 1.999 which permits air fuel ratios to be measured to greater precision. If a vehicle supports Pid 0x44, OBD 2007 fuel consumption figure is modified by the effect of Commanded Equivalence Ratio.
To assist in understanding what is going on under various driving conditions, the OBD 2007 Fuel Analysis tab also includes gauges for Short and Long Term Fuel Trims. Ideally the short term fuel trims are trying to maintain the long term fuel trims at around 0%. A negative figure is an indication of leanness and a positive figure is an indication of richness.
The final components of OBD 2007’s Fuel Analysis tab are two LEDs to indicate the state of Pid 0x03, Fuel Status. The LEDs can display 5 different colours to indicate the various states of Fuel Status.
Gray -- Unused.
Red -- System is running Open loop -- has not yet satisfied conditions to go Closed loop.
Green -- System is running Closed loop -- using O2 sensors as feedback for fuel control.
Amber -- Open loop due to driving conditions -- either enrichment or enleanment.
Orange/Gray -- Fault detected.
Because the gauge is an instantaneous fuel consumption gauge, it is quite normal for the gauge to swing wildly whenever the vehicle is accelerated quickly (high fuel consumption) or decelerated quickly (low fuel consumption). You may even notice on the digital fuel consumption gauges a reading of -Err-. This doesn’t actually signify an error, but is an indication that the fuel consumption figure is greater than what the gauge can display. E.g. if the fuel consumption is greater or equal to 100mpg, that figure cannot be displayed because there is only room for two significant digits.
When the vehicle is stationary with the engine idling, fuel consumption is zero. However the fuel rates of the right hand digital gauges will show their respective fuel flow rates. The following window below displays a typical fuel consumption window.
Please note like the Dashboard tab the Fuel consumption tab is optimised for viewing in full screen mode.
Picture of "Fuel Analysis" Gauge :
Question: What do you think? Does the equation they are using look valid to you?
CarloSW2
Old 09-02-2008, 10:12 PM   #8 (permalink)
Moderator
tasdrouille's Avatar
The Guzzler - '08 Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '011 Soul 2U
Using only the MAF data is an approximation of fuel economy assuming the car's always running at stoich. That's probably what the SGII does.
However, for vehicles with broad band sensors, their program supports adjustments from the equivalence ratio which should make reported fuel consumption more precise.
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 09-05-2008, 02:55 AM   #9 (permalink)
Greta - '00 Jetta TDI
90 day: 59.96 mpg (US)
Send a message via Skype™ to ChrstphrR
Thank you for the thread here... I think I have an idea now why my Scanguage isn't calibrating well: My MAF is failing, and thus, it's not reporting accurately, throwing the SG's tracking off.
On the A4 (or MkIV) TDI engines, the MAF sensor is notorious for failing out. I know from the slight lack of power, that mine is failing out again. So, time to sleep, so I can book more hours at work, and buy a new MAF for my car :P
Current mod: Skidplate/Undertray for my MkIV Jetta. Next mod: CAD drawing for skidplate so other Jetta/Golf drivers can make one too!
Old 10-09-2008, 07:19 PM   #10 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
Hello -
(apologies in advance for some of my "custom" acronyms. I am "programming" the variable names in the post)
I am trying to determine an approximate Instant MPG calculation for my scantool software. All of the following is based on this OBD 2007 documentation blurb :
http://www.glmsoftware.com/Documenta...de20080822.pdf - Page 15 of PDF
Here are my inputs :
- Intake Manifold Pressure (MAP) units: inHg
- Vehicle Speed units: MPH
Here are my constants/conversions :
- AFR = Air/Fuel Ratio = 14.64
Source: http://www.glmsoftware.com/Documenta...de20080822.pdf
- "DOG" = Density of Gas (g/cm3) = (0.71 +0.77) / 2 = 0.74
Source: Gasoline - Wikipedia, the free encyclopedia
- "M2K" = Convert Miles to Kilometers = 1.609344
Source: Convert miles to km - Conversion of Measurement Units
- "KML2MPG" = Convert KM/L to MPG = 2.35214583
Source: WikiAnswers - How many km to 1 litre of gas
- "SPH" = Seconds Per Hour = 3600
- "MPL" = Milliliters Per Liter = 1000
Steps to convert with example inputs from real OBD II data logging :
- Intake Manifold Pressure (inHg) = 17.542
- Vehicle Speed (MPH) = 52.533
1 - Convert MPH to KMH
=> MPH * M2K = 52.533 * 1.609344 = 84.54366835 KMH
2 - "FFG" = Calculate FuelFlowGrams/Sec
=> MAP / AFR = 17.542 / 14.64 = 1.198224044 FFG
3 - "FFL" = Calculate FuelFlowLitres/Second
=> (FFG / DOG) / MPL = (1.198224044 / 0.74) / 1000 = 0.001619222 FFL
4 - LPH = Calculate Liters Per Hour
=> FFL * SPH = 0.001619222 * 3600 = 5.829198051 LPH
5 - KML = Calculate KiloMeters / Liter
=> KMH / LPH = 84.54366835 / 5.829198051 = 14.50348189 KML
6 - Calculate MPG
=> KML * KML2MPG = 14.50348189 * 2.35214583 = 34.11430445 MPG
The MPG number looks "ballpark" correct to me, subject to programming and testing. The most iffy part to me is step 3, where I divide by 1000 to get the "FFL". I am doing this because in step 2, it is not clear that the FFG is in Liters.
Also, the OBD 2007 algorithm calls for a MAF sensor. In my S-Series Saturn, I *think* I have a MAP sensor. My question here is, what's the difference? Do I need to convert from MAP to MAF?
Based on the steps above, here is the output I get. This is based on the data logging from thread #1 :
Code:
,,INPUT,INPUT,STEP 1,STEP 2,STEP 3,STEP 4,STEP 5,STEP 6,
YYYMMDD,HHMMSS,MAP (inHg):,Speed (MPH):,Speed (KMH),FuelFlowGrams/Sec ,FuelFlowLitres/Second,Liters per hour (LPH),KMH/LPH,MPG
20080407,201137,17.542,52.533,84.54366835,1.198224044,0.001619222,5.829198051,14.50348189,34.11430445
20080407,201242,11.647,54.867,88.29987725,0.795560109,0.001075081,3.870292424,22.81478183,53.66369394,
20080407,201348,19.197,55.35,89.0771904,1.311270492,0.001771987,6.379153744,13.96379425,32.84488043,
20080407,201455,15.507,53.233,85.67020915,1.059221311,0.00143138,5.152968542,16.62540892,39.10538626,
20080407,201601,21.542,53.817,86.61006605,1.471448087,0.001988443,7.158396101,12.09908824,28.45881994,
20080407,201709,17.98,55.133,88.72796275,1.228142077,0.001659651,5.974745237,14.85050144,34.93054504,
20080407,201814,12.02,53.733,86.47488115,0.821038251,0.001109511,3.994240142,21.64989537,50.92371111,
20080407,201919,12.173,50,80.4672,0.831489071,0.001123634,4.045081967,19.89260061,46.79029757,
20080407,202023,14.567,52.8,84.9733632,0.995013661,0.001344613,4.840607,17.55427846,41.29022288,
20080407,202128,14.065,52.383,84.30226675,0.960724044,0.001298276,4.673792645,18.03722868,42.42619223
20080407,202234,15.575,49,78.857856,1.06386612,0.001437657,5.175564909,15.2365698,35.83863412
20080407,202339,14.21,50.017,80.49455885,0.970628415,0.00131166,4.721976074,17.04679515,40.09654813
20080407,202446,16.237,44.483,71.58844915,1.109084699,0.001498763,5.395547187,13.26806099,31.20841433
20080407,202549,16.167,50.583,81.40544755,1.104303279,0.001492302,5.372286221,15.15285005,35.64171307
20080407,202653,13.59,42.583,68.53069555,0.928278689,0.001254431,4.515950377,15.17525434,35.69441122
20080407,202758,15.017,43.383,69.81817075,1.025751366,0.00138615,4.990141781,13.99121985,32.90938943
20080407,202901,15.563,45.067,72.52830605,1.063046448,0.001436549,5.171577315,14.02440718,32.98745088
20080407,203003,15.853,46.233,74.40480115,1.082855191,0.001463318,5.267944174,14.12406789,33.22186739
20080407,203104,15.34,44.533,71.66891635,1.047814208,0.001415965,5.097474524,14.05969093,33.0704434
20080407,203207,16.358,48.1,77.4094464,1.117349727,0.001509932,5.435755428,14.24078906,33.49641259
20080407,203307,17.822,48.517,78.08054285,1.217349727,0.001645067,5.922241914,13.18428797,31.01136798
20080407,203409,17.785,48.25,77.650848,1.214822404,0.001641652,5.909946832,13.13900957,30.90486658
20080407,203515,23.225,52.183,83.98039795,1.586407104,0.002143793,7.717656181,10.88159358,25.59509496
20080407,203622,21.535,54.367,87.49520525,1.470969945,0.001987797,7.156070004,12.22671176,28.75900907
20080407,203724,15.088,41.4,66.6268416,1.030601093,0.001392704,5.013735047,13.28886369,31.25734531
20080407,203829,19.203,46.683,75.12900595,1.311680328,0.001772541,6.381147541,11.7735886,27.69319733
20080407,203934,16.125,48.533,78.10629235,1.101434426,0.001488425,5.358329641,14.57661204,34.28631722
20080407,204037,12.637,44.033,70.86424435,0.86318306,0.001166464,4.199268941,16.87537649,39.69334643
20080407,204148,11.128,48.117,77.43680525,0.76010929,0.001027175,3.697828977,20.94115378,49.25664754
20080407,204253,11.532,43.35,69.7650624,0.787704918,0.001064466,3.83207798,18.20554351,42.82209326
Pending programming and testing, do you think I am on the right track?
CarloSW2
