Every picture tells a story...don't it? (VTEC-E into '95 Civic CX)
3 Attachment(s)
VTEC-E into '95 CX. I've got the tubes put on correctly except that I can't find the spot on the intake to put the tube coming from the vacuum control valve, (wrong intake?), don't know what to do about that. The orange/blue wire coming from the solenoid I've put in the last spot on the P07 ECU plugs, (D22), with a green and white stock wire and another that was put in by "Altec". The black/yellow wire is put on the 15 amp ACG fuse. Can anyone tell me what is still wrong?, causing the engine light to come on? I did disconect the battery every time to clear it.
I've included some pictures to show how I hooked up the vacuum tubes, and to make sure I've got the right EGR, Vtec solenoid, etc., please let me know if something's not right. Because I couldn't find an intake location for the vacuum control valve tube I put it on the tube where the gas canister tube was and connected that tube to the part in the first picture, (far side). |
