Old 02-18-2016, 04:36 PM   #91 (permalink)
I mounted my controller, contactor, charger, cooling pump, and optical isolater inside of my gas tank so that I could have more room to mount the batteries. The top half of the gas tank bolts back onto this modified gas tank, and it just bolts back onto the car where it was as an ICE car.
The Following 3 Users Say Thank You to EVmetro For This Useful Post:
MobilOne (04-16-2016), thingstodo (02-18-2016), user removed (03-30-2016)
Old 02-18-2016, 09:35 PM   #92 (permalink)
Modding for Eris
Thalass's Avatar
SilverCivic - '08 Honda Civic
90 day: 28.69 mpg (US)
That's a really neat idea!
Making do with a Honda Civic. Tesla Model 3 reserved. Still kinda want an SVX for fun, though.
Old 03-30-2016, 03:38 PM   #93 (permalink)
BeginnerModder
I'm late to this party, but what a cool build! I sent you a PM about the CV axle cup clearance before I realized your plate cleared it. sorry.
What EVMetro is saying about the vacuum pump... pretty spot on. I drove my diesel metro to the exhaust shop last weekend and it was a bear to get whoa'd on down (that's a technical term in Texas). I bought a Hella UP28 vacuum pump on eBay and I'm going to plumb it in to a 2" piece of PVC pipe capped on both ends (a reservoir, if you don't mind the shadetreeness of it) and I also picked up a vacuum switch on eBay for 15 bucks.
The Hella 28 is not designed to be a full time vacuum pump for braking, but is supposed to "assist". It was way cheaper than the Hella UP30 and UP32 that are designed for full time use.
I will share my results.
P.S. wanna race when we are done? lol. endurance race, ok. You'd kill me in acceleration and top speed...
Old 03-30-2016, 05:29 PM   #94 (permalink)
Dorman Help! 47077 - Vacuum Tank Unit | O'Reilly Auto Parts
Pretty inexpensive factory made vacuum reservoir .
God bless
Wyr
Old 03-30-2016, 08:37 PM   #95 (permalink)
BeginnerModder
God bless
Wyr
Yeah, why make a 3 dollar one when you can buy a 12 dollar half-sized one!
Old 03-31-2016, 11:59 AM   #96 (permalink)
How long would it take to make a three-dollar one?
Old 03-31-2016, 12:04 PM   #97 (permalink)
I remember one of my late Uncles had a 1960's car . The vacuum reservoir was metal , painted black & looked like it was a 5 pound coffee can .
It was a stock , factory made item .
God bless
Wyr
Old 03-31-2016, 04:48 PM   #98 (permalink)
Here it is in my 1995 DC conversion. Works just fine.
Old 04-10-2016, 10:33 AM   #99 (permalink)
JEEZ, that looks exactly just like my vacuum tank.....
Old 04-16-2016, 03:21 PM   #100 (permalink)
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
I haven't given up or anything. I did, however, get sick as hell, and then distracted with more urgent projects.
One thing I did was test/implement my "affordable alternative" for battery protection. Here they are, hooked up to my electric bike's battery:
Tapped in at the BMS connection:
(you can see my EV cells hooked up in parallel behind them, getting properly balanced)
They're dirt-cheap battery monitors off of Ebay for about $1.50 ea. They're meant for monitoring RC Lipo batteries. Each one monitors up to 8 cells. They have a low-voltage alarm on them, which you can adjust the voltage for, starting at 2.7v and up. The alarm is decently loud, without being loud enough to drive you up the wall in a hurry.
For now, I'll couple these with a cheap BMS, which is essentially there to prevent over-charging and give a bit of balancing. They're too small to control the large currents, so some form of external cell/voltage monitoring was needed.
Crude? Perhaps. But I'm not forking another grand or more for a full blown BMS. Yet I still need to protect my batteries, or I'll end up killing off a cell at a time. This should do the trick.
I've had them hooked up to my little battery pack for over a week without charging, and the pack voltage has barely dropped a couple of tenths, in spite of the cells being in the sharp part of their charge curve, where they drop off quickly to nominal during discharge. Meaning these little guys are barely taking more power then required to light the LED displays up. No worries that I'll kill my pack by leaving it uncharged for weeks on end.
I bought something else yesterday, which has reinvigorated my enthusiasm to work on the conversion a bit. Well, like any toy, I need an excuse to use it, and I have a motor mount that needs finishing.
This is my latest deal. I love a great deal:
A lightly used Weld-Pak 155. It's a 220v, wire-feed/MIG welder. Set up for gas-less/flux core welding, but it is not difficult to convert to proper gas-shielded MIG. Has the greater part of a 11lb spool of flux core in it (they aren't cheap). Cost me about $150 Canadian.
I say about, because I cut the guy a deal and had him include a 50' 10/3 welder extension cord with it. And a 11lb spool of regular (non-flux core) welding wire:
Guy was retiring/downsizing, hence the good price and light use. I was lucky to be the first one there, particularly since I hadn't put a lot of effort in to it! Maybe the flux-core bit was enough to scare off most people, when they see the price of a conversion kit, which is like $200.
I'll be buying the few pieces I don't have already off of ebay and the like, and should be able to run gas for like $50. Except I'll need another bottle, since the pure argon with my TIG isn't so good for steel MIG welding. I'll have to be patient to find a deal on one.
OTOH, I'm curious to see how it will run if I leave the flux-core wire in, and add the pure argon to cut down on spatter. Weld quality will probably depend on just what gasses are emitted by the flux. If it'll save me the bother/cost of finding a second bottle, and won't ruin the welds, I'll be satisfied.
So, yeah, I'll start up on this project again soon, if for no other reason then to play with the welder!
conversion, electric, ev conversion, firefly, geo metro
