Old 07-28-2009, 10:00 PM   #1 (permalink)
Matt Herring's Avatar
Bone's 2010 Prius - '010 Prius Black
90 day: 56.78 mpg (US)
Gen III 2010 Prius
I picked this up from the priuschat site but thought it might be interesting to ecomodders to read about some of the details integrated into the new 2010 Prius. These bullet points are taken from current 2010 users so they might be observations rather than fact...so take them with a grain of salt if you disagree with any of them.
* The air conditioner uses an ejector cycle which causes gases to recycle and only liquified refrigerant to pass through the evaporator (cooling) coil. This increases efficiency by > 50%. http://www.globaldensoproducts.com/c...tor_cycle.html
* The 2010 Prius engine is completely beltless thanks to an electric water pump and air conditioner compressor. The valves are operated by a timing chain (which technically isn't a belt).
* The fuel delivery system for the 2010 Prius is the non-return type to reduce on evaporative emissions caused by the returning unused fuel from the fuel-injection rail.
* The muffler in the 2010 Prius has a spring loaded door within which is forced open under higher load conditions to reduce restriction, and held closed under lower power conditions for quieter operation.
* The fan motors on the 2010 Prius w/ solar roof are a different type (brushless DC dual ball bearing) to withstand the higher duty cycle of running while parked.
* The solar panel, made by Kyocera, outputs 59W at full power. The fan system requires at least 10V to power the fan.
* New engine redline is 5200rpm vs 5000rpm from Gen 2, and 4500 from Gen 1. I've only observed max RPM at 75mph+ though.
* Windshield washer jets for the front are now located below the hood instead of on top.
* The radar antenna for the radar cruise control and pre-collision systems is located behind the front Toyota badge.
* Tilt headrests as well as up/down
* Stealth mode (no ICE) can be maintained up to 46 mph (vs. 41 mph in the Gen II model)
Old 07-28-2009, 11:46 PM   #2 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.85 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 28.75 mpg (US)
...I "like" the idea of solar-cells on the roof, here in AZ, they're really get a work-out!
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SIDI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970½ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
Old 07-29-2009, 11:25 AM   #3 (permalink)
Mica Blue - '05 xA RS 2.0
90 day: 45.16 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
Good stuff - thanks for posting Matt.
Old 08-30-2010, 04:04 AM   #4 (permalink)
Interesting! Nice post...........
Autospeed article: adding a chin undertray to a 1st gen Prius MetroMPG Aerodynamics 18 08-11-2011 05:18 AM
2010 Prius unveiled: Cd 0.25, 50 mpg EPA combined, EV mode MetroMPG Hybrids 56 07-26-2009 04:48 PM
2010 Prius with Sunroof open...aero? Matt Herring Aerodynamics 11 06-10-2009 03:57 PM
Prius III has virtually the same CdA as the Prius II Daox Hybrids 4 05-30-2009 02:48 PM
Toyota's gen III prius page Daox General Efficiency Discussion 4 11-10-2008 03:28 PM
