Old 02-07-2013, 06:19 PM   #1 (permalink)
40-60-40 MPH P&G
echo-francis's Avatar
Echo-P&G - '05 Toyota Echo base
90 day: 82.76 mpg (US)
high cold idle rpm
is this normal that my cold idle rpm start at about 2500rpm and take very long to drop
Best Tank (1557.2 Km): 2.57 LHK (91.63 MPG (US) )
Best Highway Trip (~36.8 Km): 2.16 LHK (109 MPG (US) )
Best Commute Trip avg (73.8 Km ): 2.33 LHK (101 MPG (US) )
Echo-Troll Modding Thread
I know i dont have a very good write-up
no lean-burn? no good gear ratio? p&g is the answer
MPG=1 TIME=0
Old 02-07-2013, 06:25 PM   #2 (permalink)
Jyden's Avatar
Enduro E-bike - '11 PowerPedals Enduro
90 day: 2236 mpg (US)
Jota - '14 Toyota Yaris Hybrid H1
90 day: 53.11 mpg (US)
No - dosen't sound right.... Something must be wrong. Should settle at somewhat lower rpm's after a short while.
My Yaris Hybrid thread:
http://ecomodder.com/forum/showthrea...s-c-27995.html
Old 02-07-2013, 06:31 PM   #3 (permalink)
Insight for life's Avatar
05 Prius (wife's) - '05 Toyota Prius package 5
90 day: 44.32 mpg (US)
Citrus - '00 Honda Insight
Gen-1 Insights
90 day: 60.68 mpg (US)
Bad tps? (Throttle position sensor)
Old 02-07-2013, 06:35 PM   #4 (permalink)
40-60-40 MPH P&G
it starts a 2500 rpm and after about 4 sec it drop to about 2000 rpm and stays there and it drop when i am near 60c engine temp and after it really drop with the increasing temp
MPG=1 TIME=0
Old 02-07-2013, 09:18 PM   #5 (permalink)
clank - '99 jeep tj sport
90 day: 17.32 mpg (US)
vacuum leak; maybe coolent sensor
cold idle for new cars i don't think should be that high. i'd expect that from a 84 fiero but not something new.
Old 02-08-2013, 01:48 AM   #6 (permalink)
Yea seems too high, mine is 1700rpm on a cold day, 1500rpm on a warm day, drops gradually to 700 after maybe 20-30 minutes.
Old 02-08-2013, 08:25 AM   #7 (permalink)
Master Ecomadman
arcosine's Avatar
sc1 - '98 saturn sc1
Team Saturn
90 day: 43.17 mpg (US)
rans - '97 rans tailwind
90 day: 28.25 mpg (US)
red bug - '00 VW beetle TDI
big tractor - '66 ford 3400
90 day: 58.42 mpg (US)
RV - '88 Winnebago LeSharo
90 day: 16.67 mpg (US)
Take a piece of rubber hose, cut it into slices and stick it in the idle port, the small angled hole on the bottom of the throttle body. You can see it if when you take the air filter off. Put just enough so it still idles when it's first started when cold.
- Tony
Old 02-08-2013, 11:25 AM   #8 (permalink)
RobertISaar's Avatar
MC SBX - '95 Chevrolet Monte Carlo LS
Last 3: 29.75 mpg (US)
sounds normal for certain vehicles.
only way to really know would be to ask someone else with an identical vehicle or to grab a scanner capable of reading target idle speed and comparing it with reality.
