06-30-2013, 03:58 PM
#121 (permalink)
Originally Posted by Joggernot
I lived in southern NM for 15 years. I know what you went through. Every vehicle ran hot and the air-cooled motorcycle ran very hot. I never saw a semi with the radiator covers closed during the summer. Had to have all the cooling available. Air Dams were popular in Carlsbad for the Honda and small car people.
Joggernot
I can see that. I was driving the kia rio over white sands mountian and it started to heat up. I turned the A/C off and it almost went back down to the usual needle sitting point.
I found out later that the kia had an air dam and that it was torn off at some point before I bought it.
07-02-2013, 03:20 PM
#122 (permalink)
The grill shutters are installed.
For now I don't plan on including a way to close them, unless I happen to have a pull cable in my pull cable collection long enough to reach from the drivers seat to the grill shutters.
At least for now I will just hold them open with gravity and a spring.
I would like to control them with an air cylinder.
07-06-2013, 02:50 AM
#123 (permalink)
This is what it will look like, with an invisable radiator.
07-06-2013, 08:13 PM
#124 (permalink)
Looks nice!
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
07-08-2013, 10:29 PM
#125 (permalink)
halos.com
I agree. Nice work, stealth radiator and all... I seem to remember someone mentioning trying to control shutters like this with Arduino?
07-09-2013, 08:50 AM
#126 (permalink)
I think I am going to go old school and use a shutter stat.
07-09-2013, 09:30 PM
#127 (permalink)
I forgot to add that I installed 3/4 ton springs off a junk yard C20 pickup last month. The Springs were clearly not as old as the truck they came out of.
I busted out my miller625 plasma cutter and got it dirty cutting out those old half ton springs, after closer inspection they were beyond dead.
I replaced the rear shocks with bilsteins in 2006 because the ride provided by the rear end was pretty harsh, replacing the shocks didn't help much.
But now that I swapped out the springs it made all the difference in the world.
The rear sits about 2 or 3 inches higher now, the trailer hitch was almost dragging on the ground when I would load up the suburban.
Now the rear end rides nice and smooth and I don't feel every bump in the road.
Who would have figured 3/4 ton springs would provide a smoother ride than half ton springs?
I think those springs were killed by the last person that owned my suburban, they had it setup (cheaply) for some heavy towing duty.
These used springs were $60, new half ton springs from rockauto were going to be several hundred dollars. And because they were so long (54'') and heavy (>70lb each) they would have been freight shipped and I don't even know how much more that would have cost.
07-10-2013, 03:27 PM
#128 (permalink)
[QUOTE=oil pan 4;378547]I finely got around to measuring how much power it takes to turn a P/S pump.
It looks like if you can keep the P/S turning at 850rpms it takes hardly any power to turn, around 150 to 200 watts.
But when you bring it up to a more normal cruse speed say about 2,000 rpms power draw goes up quite a bit. It took a little over 500 watts to keep it turning at that speed.
For my suburban 500w gets about a half MPG.
I'm going with a clutched setup.
I seen where you posted on a diff thread about this. was this just free circulating into a bucket or beltless on vehicle test?
07-10-2013, 04:17 PM
#129 (permalink)
This test was done when I removed the radiator and had lots of room to stick a drill on there.
Other test equipment used was a kill-a-watt meter for measuing power consumption, a varrac for fine tuning drill speed and an optical tachometer so I know what RPMs the drill was turning. There was a warm up peroid for the drill and P/S pump and mutiple no-load drill rechecks.
Why would anyone remove the pump and do the test?
There would be no point, it would take a lot more work and the test results wouldn't produce any kind of useable result.
Further back in that post I discribe how I would test it and calculated the max power draw off the engine to be some where around 2 to 2.5hp.
If I spun the pump up to 3000 or more RPMs it could very well come to a point where it reaches 2hp.
07-10-2013, 09:22 PM
#130 (permalink)
halos.com
On the grill block subject, I've tested it with my truck and I actually lose a couple percent mpg with about 80% covered. Can't use it down here in the summer anyway--I think my electric fan wouldn't stop running.
Thanks for the ps pump testing. Interesting results.
Curious that 3/4 ton springs ride better. Wouldn't have guessed. Usually the shocks make the difference on the lighter end of the vehicle...
The Following User Says Thank You to ECONORAM For This Useful Post:
