Old 05-18-2018, 08:00 PM   #1 (permalink)
Citroen AX 1.5d - '93 Citroen AX
Diesel
90 day: 61.42 mpg (US)
How to mod hydraulically controled AT ?
Hey guys
I have a Citroen ZX with a 4 speed automatic gearbox, it is a ZF 4HP14 completely oldschool hydraulic control, no ECU.
The transmission shifts into 4th at about 70 Km/h but it can mantain it down to 60km/h, I was thinking of finding a way of making it shift up sooner.
Should I be loking for a vacuum line to tap into ? or adjust the kick down cable a different way? (maybe its not just kickdown)
Or is it really a no go and only real way to do it would be to change the valve body ? (Wich obviously is not practical).
Thanks for the help
Old 05-18-2018, 11:52 PM   #2 (permalink)
me and my metro's Avatar
Economy Saturn - '02 Saturn L200
It looks like a cable only trans. Most cable controlled transmissions use the cable to control line pressure. I would loosen the cable and see if it upshifts sooner. You can also go inside and play with the governor springs.
02 Saturn L200 5 speed- 265k miles
84 Gmc 6.5 na diesel K30 4x4, TMU
2006 Lincoln Navigator, 215k miles
Old 05-19-2018, 03:45 AM   #3 (permalink)
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
I really wouldn't mess with the transmission shift points unless you have a trans temp gauge. The sooner it shifts, the more it will drop in and out of overdrive, thus 'slipping', the more heat you make.
Old 05-22-2018, 01:13 PM   #4 (permalink)
Diesel
OK thanks guys I will see what I can do.
