Old 09-04-2017, 05:12 PM   #1 (permalink)
Underbody Materials
Looking at making a flat underbody and am looking for suggestions of material types.
Do they make 4x8 sheets of ABS plastic in 1/8 or something? Do i run risk of it melting around the exhaust/radiator?
Old 09-04-2017, 05:32 PM   #2 (permalink)
90 day: 40.51 mpg (US)
I've had corrugated plastic under mine for a few years now. The exhaust curled back the plastic where it was touching near the engine, but was cool enough toward the rear that the plastic remained unharmed. It seems to have survived pretty well - there's discoloration, but no holes from rocks or anything.
What it was like new:
aerohead (09-09-2017)
Old 09-04-2017, 07:48 PM   #3 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Coroplast works well and is pretty inexpensive and forgiving. I started out with Coroplast (free from the elections) and have since moved on to aluminum diamond plate.
Dark Aero-The world's first aerodynamic single wheel boat tail!
The Following User Says Thank You to BamZipPow For This Useful Post:
Old 09-04-2017, 07:50 PM   #4 (permalink)
Coroplast is also extremely lightweight.
Old 09-04-2017, 09:41 PM   #5 (permalink)
How did you guys choose to mount them? What kind of fastners? Did you drill some holes in the frame and stick some rivnuts in there?
Old 09-04-2017, 10:07 PM   #6 (permalink)
I was lucky that my car already has fastener holes. I removed the very basic factory undertray and attached the coroplast using the factory bolt holes.
Old 09-05-2017, 01:45 AM   #7 (permalink)
If you feel uncomfortable with that, maybe could try some of those thermal insulating wrap-around materials that some folks use in the exhaust of their cars. But anyway, why not consider plywood since it's already used for underbody protection in racing applications?
Old 09-05-2017, 07:35 AM   #8 (permalink)
I'd lean towards coroplast since it's more leightweight than plywood. But other than that, plywood works too, I think
Old 09-05-2017, 11:12 AM   #9 (permalink)
Wood rots, coroplast sags.
Polymetal is polypropylene plastic skinned in aluminum. Typically 3mm thick with .007" skins, but it's available one-sided and Grimco MaxMetal is avaiable with .014" skins. It comes in 5x10ft and 4x12 sheets. Stiff as 5/8" plywood at 1/10th the weight.
Yes it is expensive; but it's fit for purpose.
Shepherd777 (09-17-2017)
Old 09-05-2017, 12:05 PM   #10 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Wink
I made a crossbeam setup so I wouldn't have to drill the frame or body fer fasteners or support. It also makes it easier fer me to take off seperate panels instead of the entire belly pan when it comes to maintenance.
http://ecomodder.com/forum/showthrea...pan-22621.html
Jack-Lee (09-30-2017)
