Old 08-12-2009, 11:26 PM   #11 (permalink)
No, I live in quite a cold climate. I do, however, have a garage that I keep the car in for most of the winter. This reduces the requirement for immediate defrosting and engine warm up. When at all possible (and I can't even remember if I did use it last year) I do not use the rear window defroster. I wait for the car to warm up and then use the car's heat to defog the rear windows.
Headlights are probably the biggest hit (the fan on high is a close second), and it will take its toll on the battery. However, I have driven on cloudy rainy days with the headlights on and have had no problems besides the deep cycle battery needing a bit more juice when I get home. Radios use very little power and are of little concern thankfully.
I should qualify that my commute is not the shortest either. I have about a 42 mile (62 km) round trip to take each day. The trip can take anywhere from 30 minutes to an hour if traffic is bad. I am using a used group 24 (which are usually 70-85Ah) deep cycle battery. When I plug it in for recharging the battery usually is at 70-80% charged. The day I ran headlights/wipers I think I was down to 60% or so. So, if you had a longer commute, you could simply go with a larger battery, or two in parallel.
alternator optional, solar panels
Pulse & Glide + Flywheel Energy Storage Jambrain General Efficiency Discussion 3 06-12-2011 06:59 PM
Win $100.00 in Free Gas! Design Contest: Ecomod my Ride XFi EcoModding Central 127 02-17-2011 12:07 AM
The Mechanism Behind Flow Separation LostCause Aerodynamics 46 07-15-2010 07:38 AM
Geothermal energy? DifferentPointofView Saving@Home 46 02-05-2009 10:15 PM
Energy shortage? There's never any Energy shortages Peakster The Lounge 5 04-10-2008 10:06 PM
