Go Back   EcoModder Forum > EcoModding > EcoModder Blog Discussion
Old 03-19-2013, 01:17 PM   #1 (permalink)
Als Hx - '96 honda civic hx
I want to buy a Mpguino but am not sure it will work with lean burn, help.
Hi everyone I'm new here and have read plenty of post about leanburn and gauges. I resently bought a honda civic hx and want to start tracking my mpg to find the best mpg. I have read good things about Mpguino. Can someone point me in the right direction?
Old 03-19-2013, 01:42 PM   #2 (permalink)
does anyone know if the mpguino can be conected to the OBD2?
Old 03-19-2013, 01:47 PM   #3 (permalink)
razor02097's Avatar
Tetanus - '95 Geo Tracker 4WD Base
90 day: 29.43 mpg (US)
300 - '82 Suzuki GS300 L
Last 3: 60.78 mpg (US)
Jeep - '98 Jeep XJ Cherokee Limited
90 day: 12.82 mpg (US)
Sorry I can't answer the first question but...
If you are asking if the MPGuino connects to the OBD2 connector no.
If you are asking if the MPGuino can be installed in an OBD2 vehicle yes.
The MPGuino uses an injector signal and a VSS signal. You would connect to the appropriate wires so it won't connect to the ECU.
Project Avalon: E bike build
Old 03-19-2013, 02:05 PM   #4 (permalink)
I see that there are many satisfied people who bought mpguinos from Dave (dcb). how do I contact him?
Old 03-19-2013, 02:07 PM   #5 (permalink)
thanks Razor I was just hoping that I could just conect the gauge without having to spice some wires.
Old 03-19-2013, 02:27 PM   #6 (permalink)
does the mpguino show engine load and tps and rpm?
Old 03-19-2013, 03:12 PM   #7 (permalink)
The mpguino is an MPG gauge. It connects to the injector signal and your speed sensor. That is all. No other information can be squeezed out of it if you tried other than fuel consumption vs speed.
Old 03-19-2013, 03:38 PM   #8 (permalink)
thanks 96-civic-ex, I had seen that scangauge does that and it makes it easier to know when lean burn should be able to activate. I also read that scanguage reads 00000 when lean burn is activated. Does amyone know what the newest version of mpguino is or the best version?
Old 03-19-2013, 03:43 PM   #9 (permalink)
I ment to write 97-civic-ex not 96 sorry
Old 03-19-2013, 04:04 PM   #10 (permalink)
razor02097's Avatar
It is an open source gauge so I won't say a definitive no but most do not.
His website is => DSchmidt Technologies Look at the bottom for his email. He is also here so you can PM jellybeandriver.
