Old 04-09-2009, 06:40 PM   #1 (permalink)
Manic Rabbit
Southcross's Avatar
Slow-n-Low - '81 Rabbit S
90 day: 33.97 mpg (US)
Method to madness (Fuel Economy Testing)?
So, I've begun planning my modifications... What's got me stumped is how in the world, around the "Mile High City", I'm going to perform my testing. Between Wind/Weather/Temp, Traffic, hills & FRAKING MOUNTAINS... I know I need "apples" to "apples" tests, so Idealy I don't want to break my tests up over inconsitant periods of time.
so.... I'm Wondering...
Should I plot a simple "Repeatable" path? (instinct tells me yes)
How long should should the drive be? Approximate 1 Gal usage (i.e. Approx 30 miles), 2 Gal (60 miles)?
I'd think that for the best apples-apples comparison, I should attempt to fill up at the same station?
I know in the "scientific" world they have pre-metered fuel, measure distance and how long it takes to go through said amount of fuel... (or how much is remaining and figure out usage divided by distance)... I don't have that kind of luxury
-Edward
Driven on Colorado roads, where NOTHING is flat
Present City 3x / Highway 4x
Goal: 4x / 5x
Old 04-09-2009, 07:04 PM   #2 (permalink)
WonderWagon - '94 Escort LX
Last 3: 51.52 mpg (US)
DaRedOne - '99 Escort ZX2 Hot
DaBluOne - '99 Escort SE
90 day: 48.97 mpg (US)
Carbureted (so mpguino won't work)?
If so, where is the fuel pump located?
If you don't want to burn lots of gasoline just testing, I'm thinking a manually switched aux fuel tank - like a full sized pickup or suv with dual tanks - only a super tiny 2nd tank (1-2 quarts). Even at only $2/gal it won't take many test runs to pay for itself.
Old 04-09-2009, 08:06 PM   #3 (permalink)
Big Dave's Avatar
The Red Baron - '00 F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Impala SS
90 day: 21.03 mpg (US)
I do my testing using my fairly long (50 miles one-way) balanced (one-third urban, one-third rural roads, one-third Interstate) circuit for real-world MPG testing.
Since I don't have precision fuel metering equipment, I use long tests and all the inaccuracies average out.
As A result I think a valid MPG testinvolves about 1500 miles. Four fill-ups.
ScanGuage is OK for short-term comparative tests, but snapshots are NOT real world MPG
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Hard Tonneau and Rugged Air Dam
Old 04-10-2009, 10:50 AM   #4 (permalink)
Manic Rabbit
Southcross's Avatar
Mechanical CIS fuel injection... the fuel pump runs a super high PSI (75psi minimum), a minimum flowrate of 85L/hour, plus if it runs out of gas flowing through they tend to burn up ($185 new).... not to mention a significant air-bubble in the CIS system can lead to all kinds of issues.
There is no actual "ECU", only an Emissions Control Unit to fine-tune adjust the mixture.... saddly to Stoich (I've got my work cut out for me to hit my goals of 35/40 MPG)... so Scan Gauges and the like are no-bueno
-Edward
Goal: 4x / 5x
Old 04-10-2009, 10:54 AM   #5 (permalink)
Manic Rabbit
Southcross's Avatar
hmmm... good point on the "mix", I think I can pull off a good 50/50 of Highway/City
-Edward
Goal: 4x / 5x
Old 04-10-2009, 10:59 AM   #6 (permalink)
PaleMelanesian's Disciple
hummingbird's Avatar
City - '04 City iDSI EXi
90 day: 47.47 mpg (US)
Southcross, Just to get the context... What makes you persist with this old ghost of a vehicle?
Old 04-10-2009, 12:09 PM   #7 (permalink)
Manic Rabbit
Southcross's Avatar
becha I spend less on maintenance in a year than what you pay for insurance and bank note in a month
-Edward
Goal: 4x / 5x
Old 04-10-2009, 12:46 PM   #8 (permalink)
Bicycle Bob's Avatar
Appliance White - '93 Metro 4-Dr. Auto
Last 3: 42.35 mpg (US)
Stealth RV - '91 Sprint Base
Bravo. I averaged under $200 per year for parts and depreciation on old Toyotas for a decade. I think my cars are appreciating now, but it is taking more work. Considering what generating money does to the planet, no expense is unimportant - the fuel bill is just the hardest one to work on. Replacing a car makes a lot of factory smoke.
Old 04-10-2009, 12:57 PM   #9 (permalink)
Manic Rabbit
Southcross's Avatar
don't get me wrong.... if your going to buy a new car, get the most efficient one for your buck... but if your going to replace a carjust for the economy, it reminds me of the saying "The Prius is an Economy car for people who can't do math". A $300/month car payment + Insurance for 30% better gas mileage that what I'm getting right now.... I would have to drive 6,500 MORE miles per month to "save" money
-Edward
Goal: 4x / 5x
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 155 05-01-2012 09:33 PM
Fuel Economy related papers tasdrouille General Efficiency Discussion 33 03-06-2012 12:22 PM
mileage computer for a carbureted engine diesel_john Instrumentation 162 07-18-2010 05:31 PM
smart cdi (diesel) owner from BC, Canada smartzuuk Introductions 23 04-10-2010 12:22 PM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
