A Montana outfit thinks they have the secret to inducing lean burn on <2005 cars.
What We Do
This outfit thinks they know how to induce 18:1 lean burn with emissions improvements (including reduced NOx somehow) using an aerodynamic device in the throttle body. |
The Gadgetman Groove by another name.
Idiots. Almost all intake manifolds for EFI are "dry"; fuel is injected adjacent to the intake valve so their "turbulence" does little or nothing. And for the throttle-bodies I fail to see how this would help either. |
I don't think so.
Yes, idiots absolutely. It's a pretty sh!t little piece of kit. It won't do what's claimed. Surely, if the concept works, a rifled wall behind the TB would be even better. But it's not likely to work.
Unicorn corral here we come.
Yeah, it's pretty much bull****.
Are you sure this should be in the unicorn corral? I am pretty sure he wouldn't make up the part about the "complete elimination of noxious gas emissions".
And everyone knows that Q-jet carbs can't be turned upside-down like Holley's and Edelbrock's :D |
It may eventually induce a lower fuel amount to be injected, but since that device is a restriction to the airflow I wouldn't call it lean-burn.
