Old 02-02-2010, 12:24 PM   #1 (permalink)
multiple alternator use
i was wondering is any of you could answer this question.
if put in the vehicle or in a tow along. couldn't you just recharge or keep the battery/s charged using simple alternators like a standard car does now?
i.e
a alternator for each battery and the alternator/s r powered by a separate motor(just 1 motor to power all (gas, diesel,or electric))
i search the internet and the forum but no one ever talks about using more than 1 to just keep charged individual battery's .
the standard voltage regulators would prevent over charge...so i would think they would or could just run at a standard speed with no problem and keep batteries charged.
Old 02-02-2010, 12:34 PM   #2 (permalink)
Are you talking about keeping 2 charging systems separated so that 2 separate batteries can be used independently of each other? Several companies make solid state isolators for that, way simpler than using multiple alternators in an already cramped engine compartment High Performance 90-amp Battery Isolator | Overstock.com
2002 WJ Overland E85/gas flex
2002 Motobecane 700DS
1978 ChevroLegs
The Following User Says Thank You to shovel For This Useful Post:
Wantingtomod (02-02-2010)
Old 02-02-2010, 12:52 PM   #3 (permalink)
yes that is similar to what I'm talking about. and that would even make less weight and load on secondary engine. also wouldnt using that keep you charged allowing higher mileage and would only limit you to the fuel running out(in the secondary engine) and then eventually killing the power pack.
Old 02-02-2010, 08:30 PM   #4 (permalink)
ecomonkey
silver clown - '02 echo 2 door base
90 day: 45.91 mpg (US)
in what kind of car or set up are you talking about ,an electric? a hybrid?
Old 02-02-2010, 08:41 PM   #5 (permalink)
in a all electric car in thought...the 2nd engine mentioned is 2 be just a power source to power the alternators ... i.e. (a second electric source ...in my thoughts)
Old 02-02-2010, 08:52 PM   #6 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Zombie Insight - '00 Insight MT
90 day: 62.82 mpg (US)
This pic reminds me of a picture floating around the interwebs where some guy installed four * 140A alternators in his pickup, to power his radio. That's about 7.8KW of power, versus my 1.0L hybrid's 10KW onboard generator. Anyway, he could use his alternators for regenerative braking.
There's probably cheaper ways to achieve the same result, though.
Old 02-02-2010, 09:05 PM   #7 (permalink)
ecomonkey
wanting to mod why not a generator powering a battery charger then?
Old 02-02-2010, 09:30 PM   #8 (permalink)
lol i wish i found that pic on the web ...lol...i used paint to make...lol...just to make sure to show what i was taking about...lol...but anyway....i not talking about radio or stuff like that...just basic...battery recharge like a regular car does....not extra ...just basic...i'm not a expert mechanic or nothing...but...can u do the same with alternators vs your expensive 1.0L hybrid's 10KW onboard generator...im still learning about the the regen braking....but a regular car seems to always keep the battery charged....thats what im looking at...maybe im in the the wrong direction
Old 02-02-2010, 09:47 PM   #9 (permalink)
im just trying to keep it to the basic (kis)...like a basic car...from what i read generators involve alot more electronic parts and more monitoring were as a simple alternator is good or bad and your battery/s can at least have a chance of not being ruined ...my experience has showed me in the past of a bad alternator or battery that at least 1 can be saved ...whereas a generator can over/under produce and cause lose of everything(i.e. a power surge in a house)...maybe i wrong ....
Old 02-02-2010, 09:47 PM   #10 (permalink)
ecomonkey
the regen turns the motor into a generator during breaking, but it will absorb in the kilowatts of energy quickly! but the motor adds zero dead weight or drag because it also drives the wheels, if you are adding a bunch of alternators thats alot of weight and drag?
you will never come close to the effectiveness of the hybreds system, if you wanted to use the alternators to slowm you down by hitting a switch that would activate your feild windings that would present drag on a driveshaft and slow you down and also generate power, but i cant see it being a positive thing ( you'ed lose more than you would gain,if i understand what you are tring to do.
alternators, battery, charge, k.i.s., multiple
ZF ecomods a transmission: 8 spd auto, EOC-able, multiple input options, fewer parts MetroMPG EcoModding Central 5 01-02-2010 11:02 AM
GM: Chevy Volt's Cd is 0.28, Prius is 0.30 (tested in multiple tunnels), EV1 is 0.21 MetroMPG Aerodynamics 65 12-17-2009 08:38 PM
