Old 12-08-2012, 12:08 AM   #11 (permalink)
BamZipPow's Avatar
BZP T-100 (2010) - '98 T-100 ext cab - 3.4L/auto SR5
90 day: 20.99 mpg (US)
BZP T-100 (2011) - '98 T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 T-100 ext cab - 3.4L/auto SR5
90 day: 19.68 mpg (US)
BZP T-100 current (2013) - '98 T-100 SR5
90 day: 20.61 mpg (US)
Send a message via ICQ to BamZipPow Send a message via AIM to BamZipPow Send a message via MSN to BamZipPow Send a message via Yahoo to BamZipPow
I wonder if one could use one of those portable induction cooktops to heat up the oil with...
I guess I'll have to see what it would take to heat up the oil pan with one...
Old 12-08-2012, 08:05 AM   #12 (permalink)
nemo's Avatar
Chief - '06 Grand Prix Base
90 day: 29.08 mpg (US)
SF1 - '012 Fiesta S
90 day: 28.55 mpg (US)
Portable induction cooktops to heat up the oil, it's just amazing the ideas this site generates.
Hopefully it won't cook the oil.
Old 12-08-2012, 01:39 PM   #13 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...put new meaning into the term "Baked Alaska (oil)" wouldn't it?
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SFI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
1971 Dodge Charger 318 3A
1970½ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
Old 12-08-2012, 07:06 PM   #14 (permalink)
BamZipPow's Avatar
Talking
Portable induction cooktops to heat up the oil, it just amazing the ideas this site generates.
Since induction heating is so efficient...one would expect it to outperform the standard radiating coil types. Looking to find a broken induction top so I can strip it down and embed the coil on the outside of the oil pan. Place a rubber mat between the element coil and the pan to keep the vibration from destroying the element coil. The only problem would be is that the control panel doesn't allow fer auto on when the power is plugged in so using a timer to start it might be out of the question. I'll have to do some brainstorming to bypass that some how...maybe a relay system. Who knows.
I'll have to do an experiment to see how quickly the oil will come to temp. Maybe an old oil pan filled with 5 quarts of motor oil and placed on top of the induction burner. Time how long it takes fer the oil to hit the upper temps and when it starts to level out. Maybe sample the temp at 2 minute intervals along with the ambient temp.
If this works...could you imagine using an induction heater setup on an iron engine block to preheat the coolant? Even something like an iron reservoir that was plumbed into the cooling system might work, too.
Old 12-09-2012, 08:20 AM   #15 (permalink)
nemo's Avatar
SF1 - '012 Fiesta S
I think the idea is great.
Title for the thread. "How to cook your way to better MPG"
To warm the coolant a ferromagnetic material sleeve could be added to the lower radiator hose and a unit attached there.
Old 12-09-2012, 08:36 AM   #16 (permalink)
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
Rubber might get nasty if it gets too hot.
Old 12-09-2012, 10:27 AM   #17 (permalink)
Intrepid3.2 - '00 Intrepid ES
Team Dodge
90 day: 23.97 mpg (US)
Pacifica3.5AWD - '04 Pacifica Touring
Team Dodge
90 day: 20.74 mpg (US)
wow, i guess i need to delete my oil cooler, or maybe just relocate it inside the engine bay for winter.
Old 12-09-2012, 11:42 AM   #18 (permalink)
Just cover it. Even something like tin foil would work.
Old 12-10-2012, 08:01 PM   #19 (permalink)
So then an oil pan warmer might produce better fe than a block warmer. I wonder if this is in part caused by oil viscosity? The 212 oil temp is that the spec for your car? I know this is a general rule for block temp.
I believe this myself and have said it before with little support. As you say the oil comes up to temp so slow and the head is where the combustion is so it comes up fast.
Just acedotal but my mom lives on top of a hill and there is a huge noticible difference in engine braking (& injectors off) going down that decline on a just started engine vs an up to temp one. The only factor involved is oil viscosity.
I see it on my scangauge too, air temperature is irrelevant on my idle fuel economy, its all coolant and oil temp, I did see a difference too when I changed oils from summer to winter oil.
The Following User Says Thank You to Duffman For This Useful Post:
ksa8907 (12-10-2012)
Old 12-10-2012, 08:16 PM   #20 (permalink)
You might also try a thermostat in the oil line to bypass the cooler until the temps are getting up there.
Peter.
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
