04-07-2017, 02:02 PM
#3091 (permalink)
PaulH
I think Jack Rickard has the plug now for $1300. That's still absolutely stupid.
My goodness, They really should have just had some sort of anderson connected with heatshrink around the ends for the high voltage, and maybe a different connector for the low power part, and software can deal with making sure both are plugged in at the same time. $3000 for a connector retail is like they are trying to make the whole thing fail on purpose.
I found a bug in the split phase code. I hooked up ONLY the solar panels straight to the inverter, and everything worked great. The higher the load, the 500v just sags down until the power is sufficient (running the mill sagged the solar array down to 475v), and then the inverter just takes the 475v and puts out 120/240. As long as the solar is above 340v, it can do 120v/240v out. Now, here's the bug!
I was not actively forcing the 2 120v to be balanced. So, now I need to monitor the AC output voltages, and then change the duty of the middle channel so that it stays 120 and 120. The mill caused it to be 110 130. So, all you have to do is, say HEY! ONE IS 130, change the 50% duty to 45% or whatever so that the 110 gets pushed up and the 130 gets pushed down.
The panels had no problem with the startup surge on the mill, which can go to 200amp. After work I'm going to get a 2 1/8inch drill hole maker at Ace (as well as some popcorn for my 5 year old from them! haha) so I can add that 4 wire 240v dryer plug out at my shop, so I can charge the car directly from the solar. I'm really happy with how it turned out. Now I don't have to have any batteries out there.
The Following 2 Users Say Thank You to MPaulHolmes For This Useful Post:
04-07-2017, 02:59 PM
#3092 (permalink)
That's why I was looking for the diameters and lengths of the pins. If you can 3D print the connector, you should be able to CNC the pins from copper stock and then electro-plate the tin to minimize the corrosion ... solder or crimp them in place ... for less than $1300!!!
Putting the correct force on the pins to minimize heating .. may be a bit trickier?
In THEORY there is no difference between Theory and Practice
In PRACTICE there IS!
04-07-2017, 04:00 PM
#3093 (permalink)
Way back around 2011 there was a guy that made his own plug. Diyelectriccar is where I believe I read that. Gonna have to do a search in a bit, if someone else doesn't do it.
04-07-2017, 04:10 PM
#3094 (permalink)
First - can I get a copy of that code. It will run in my existing AC controller, right?
Second - what happens below 340VDC? Will it still balance the phases but have the voltage lower .. or does it trip? I want to minimize the number of batteries that I need to drag around with me. 150 - 170 VDC should be good for single phase 120V. If I can run off 2 packs (250 - 270V) it would help. Running from one pack (125-135V) at maybe 85 VAC would be awesome!
I have a Better Place pack that I can use, with it's own pre-charge circuit, to power the bus. It's split into chunks of 128V (135V when full). AND I'd love to run my sump pump ... about 800 feet from the nearest available receptacle.
It's getting wet .. spring is here ... and if I can get rid of water *AND* play with Power electronics ... AND batteries ... this weekend ... well, I'd like that
04-07-2017, 04:15 PM
#3095 (permalink)
Right you are
J1772 Adapter | Home
Male and female ends, pins, assembled and tested cables, etc
Much less than $1300
The Following User Says Thank You to thingstodo For This Useful Post:
04-07-2017, 04:30 PM
#3096 (permalink)
I see that someone did beat me to it.
Paul, I have a bunch of Leaf modules, some of which I would be willing to swap for a working board with maybe some testing for altermotor code or whatever.
These stack nice and neat for a solar bank. We can PM details.
04-07-2017, 04:44 PM
#3097 (permalink)
PaulH
My car has both the J1772 as well as the Chademo plug. I think the J1772 is the cheap one, and the chademo is the freakishly expensive one.
04-07-2017, 04:55 PM
#3098 (permalink)
Sorry - searched for Chademo and J1772 popped up instead.
04-08-2017, 01:28 AM
#3100 (permalink)
He faced the same problem (unobtainium) plugging into the Tesla battery junction box so he made two copper plates and jammed them in the holes and then built his own box onto them.
The same junction box BTW that shorted in the Tesla in Norway and the car burnt down from the plastics in the interior, not the batteries.
