Old 10-26-2011, 10:12 AM   #1 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
Project pretty prius grill block
I've been wanting an upper grill block for the Prius for quite some time now. Especially now with the PHEV kit and a short commute my engine doesn't even get up to temperature on the way to work and its not even winter yet! After seeing CigaR007's wonderful looking grill block I had to have one for myself. However, There was no way I was going to remove my entire front bumper cover just to make a grill block. Instead, I had recently picked up a great stuff gun for doing some home improvement work. I decided to give it a try for shooting a foamed in place grill block.
I started it last night. I did as CigaR007 did and put down a layer of aluminum foil to act as a backing for the foam. I then just shot the foam in with my gun. The whole process went pretty fast. I was done taping/foiling and shooting the foam within about 45 minutes.
I'll get more pictures later on, but here is what I have so far.
The Following 7 Users Say Thank You to Daox For This Useful Post:
aerohead (11-03-2011), BamZipPow (10-26-2011), California98Civic (10-28-2011), CigaR007 (10-26-2011), Patrick (10-26-2011), TomO (10-26-2011), vtec-e (10-26-2011)
Old 10-26-2011, 01:06 PM   #2 (permalink)
Vekke's Avatar
Siitin - '98 Cordoba Vario
90 day: 58.56 mpg (US)
Starppa - '96 Starlet
90 day: 35.06 mpg (US)
Aeroscania - '97 P94D 260
90 day: 9.35 mpg (US)
VW Lupo 3L --> 2L - '00 Lupo 3L
Diesel
90 day: 63.49 mpg (US)
When you shape that foam into shape and smooth the plastic padding with sanding paper. You can check the curvature with that aluminium foil also. Just sweep it ovet the plastic padding and you can see the bigget faults in the vurvature without painting it first . Foil mirror the surface pretty nicely.
www.tuneko.com
Less drag = Less fuel
Old 10-26-2011, 01:12 PM   #3 (permalink)
vtec-e's Avatar
De Yaris - '04 yaris T2
90 day: 69.55 mpg (US)
Good job! Ciga seems to have started something!
Old 10-26-2011, 04:22 PM   #4 (permalink)
OurInsight - '06 Insight
Hey, now that is a neat approach. I think I'll try some of this with my Insight. One could quickly make a couple of grill blocks, one for cold weather and one fore moderate weather and just keep the alternate in the trunk.
What is the spray material? I don't recognize it.
Old 10-26-2011, 04:29 PM   #5 (permalink)
CM400E - '81 CM400E
For this one I used Great Stuff window and door. It was what I had attached to my gun already, so thats what I used. We'll see how it is to actually work with. It is pretty flexible once cured.
Old 10-26-2011, 05:17 PM   #6 (permalink)
Efficiency Aficionado
CigaR007's Avatar
GreenTurtle - '01 Echo Sedan
90 day: 42.53 mpg (US)
Looking forward to the end result !
Old 10-26-2011, 06:05 PM   #7 (permalink)
tru
tru - '05 Focus ZX3
90 day: 39.46 mpg (US)
the truck - '02 Sierra Denali
how much was the foam? in my area its usually pricey
Old 10-26-2011, 08:28 PM   #8 (permalink)
BamZipPow's Avatar
BZP T-100 (2010) - '98 T-100 ext cab - 3.4L/auto SR5
90 day: 20.99 mpg (US)
BZP T-100 (2011) - '98 T-100 ext cab - 3.4L/auto SR5
90 day: 20.93 mpg (US)
BZP T-100 (2009) - '98 T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (current) (2012) - '98 T-100 ext cab - 3.4L/auto SR5
90 day: 19.56 mpg (US)
Send a message via ICQ to BamZipPow Send a message via AIM to BamZipPow Send a message via MSN to BamZipPow Send a message via Yahoo to BamZipPow
Wink
Should be about $3-$4 a can. Walmart, Home Depot, Lowes should have it in stock. Same goes fer Ace Hardware/True Value Hardware stores.
Old 10-26-2011, 08:29 PM   #9 (permalink)
CM400E - '81 CM400E
Foam in a can is 3-4 dollars around here I think. As I mentioned I used a great stuff gun, it gives much better control and is reusable unlike a normal can of great stuff. I have a picture of it below.
As you can see, you just tuck the aluminum in as best you can around corners and tape it down on the edges.
This is the great stuff gun (pro 14). Its great.
Tonight I sanded down the grill block. It went pretty quick. The only difficulty comes from the fact that the foam is a bit spongy. If you aren't a little careful you can end up ripping it instead of sanding it.
Removed the grill block and trimmed the edges.
As you can see, the surface is far from perfect. I'm going to put some fiberglass over the front face to reinforce it. We'll see what its like after the fiberglass goes on.
The Following 5 Users Say Thank You to Daox For This Useful Post:
BamZipPow (10-26-2011), California98Civic (10-28-2011), mjboks (11-22-2011), Nevyn (11-01-2011), Piwoslaw (10-27-2011)
Old 10-26-2011, 08:33 PM   #10 (permalink)
BamZipPow's Avatar
Keep in mind that the aluminum foil can scratch up yer grill if you leave it on there. Another option would be to use some plastic food wrap as yer release agent...
The Following User Says Thank You to BamZipPow For This Useful Post:
ECONORAM (05-05-2012)
