Old 02-08-2015, 10:27 AM   #1 (permalink)
Champagne - '13 Chevy Cruze 1LT
90 day: 33.35 mpg (US)
Radiator Fan activation temperature
I was curious if anyone knows if there is an OEM document out on the interweb or a website with information concerning the radiator fan activation temperature? If not could using an led in series with the radiator fan relay work to determine activation temperature?
Old 02-08-2015, 10:43 AM   #2 (permalink)
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
It varies from vehicle to vehicle. Yes you can, it's extremely easy.
The Following User Says Thank You to Baltothewolf For This Useful Post:
BrandonMods (02-08-2015)
Old 02-08-2015, 10:50 AM   #3 (permalink)
what value resistor do you place upstream of the led is my question then, or is the draw so small that you do not have to worry about the led exploding? Also would I have to use a scangauge to get the exact temperature of activation?
Old 02-08-2015, 10:59 AM   #4 (permalink)
Furry Furfag
Not sure about the resistor and yea, an ultragauge is also an option at 1/2 the price, I have a UG and I prefer it over the SG personally.
Old 02-15-2015, 04:43 AM   #5 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
If you have a SG you can tell when the fan is running by watching the engine temp. Engine gets hot> fan comes on> temp back to normal. The fans come on on both my Fiat and Renault at 93*C, if the temp is below that, I know the fan's not running. It basically never runs.
Old 02-15-2015, 09:12 AM   #6 (permalink)
I was kinda bummed for that exact reason that my car does not have the digital option for coolant on the DIC :/
Old 02-15-2015, 09:28 AM   #7 (permalink)
Spaced out...
spacemanspif's Avatar
The New Focus - '07 Ford Focus ZX5
90 day: 32.44 mpg (US)
I'm guessing it's somewhere around 210-220. Factory stat should be 190 so the manufacturers give the fans a little time before cycling on; turning on at 200 would have your fan running constantly.
-Mike
2007 Ford Focus ZX5 - 91k - SGII, pending upper and lower grill bocks - auto trans
1987 Monte Carlo SS - 5.3/4L80E swap - 13.67 @ 106
2007 Ford Focus Estate - 230k - 33mpg - Retired 4/2018
1995 Saturn SL2 - 256K miles - 44mpg - Retired 9/2014
Cost to Operate Spreadsheet for "The New Focus"
Old 02-15-2015, 10:05 AM   #8 (permalink)
nemo's Avatar
Chief - '06 Pontiac Grand Prix
90 day: 26.7 mpg (US)
SF1 - '12 Ford Fiesta S
90 day: 30.95 mpg (US)
On my car (06 GP 3800 Series III L26. ) the operating temperature range 194 to 225. The cooling fans with the air off won't come on until the temp reaches 220 degrees then turn back off at 197 degrees via the u gauge. So the below information seems accurate for the 3.1L or 3.4L V-6 Engine (VINs J, E - RPOs LG8, LA1)
The PCM commands Low Speed Fans on under the following conditions:
Engine coolant temperature exceeds approximately 106°C (223°F).
A/C refrigerant pressure exceeds 1310 kPa (190 psi).
After the vehicle is shut off if the engine coolant temperature at key-off is greater than 140°C (284°F) and system voltage is more than 12 volts. The fans will stay on for approximately 3 minutes.
The PCM commands High Speed Fans on under the following conditions:
Engine coolant temperature reaches 110°C (230°F).
A/C refrigerant pressure exceeds 1655 kPa (240 psi).
When certain DTCs set.
Engine Coolant Indicators
Engine Coolant Temperature
The IPC illuminates the engine coolant temperature indicator when the body control module (BCM) determines that the coolant temperature is greater than 123°C (253°F). The BCM receives a class 2 message from the PCM indicating the coolant temperature. The BCM sends a message to the IPC via the class 2 requesting illumination.
Engine temperature - Car Forums and Automotive Chat
I believe the factory thermostat is 195
The Following User Says Thank You to nemo For This Useful Post:
BrandonMods (02-15-2015)
Old 02-15-2015, 10:11 AM   #9 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
1998-2004 LH cars (intrepid, lhs, concorde, 300m) fans came on low between 216 and 223 depending on a/c usage and engine size.
Old 02-15-2015, 10:24 AM   #10 (permalink)
The temperature sensors on act as thermoresistors do they not? If so wouldn't it be possible to used the resistance value or voltage drop across the coolant temperature sensor to figure when the relay for the radiator fan will open?
