Old 10-26-2009, 05:35 PM   This thread is in the EcoModder Project Library | #1 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
90 day: 42.23 mpg (US)
Rain Gutter Side Skirts
Hello -
The wonders of Saturn plastic paneling helped me again. I took a rain gutter and attached it as a side skirt to my SW2 :
This has been bubbling around in the back of my head for a few years. I can't believe how easy it was to do. I just :
1 - Removed the plastic rocker panel, held on with the plastic push bolt thingys :
2 - Figured out that I had a lot of "interior volume" to work with :
The holes for the drop-down bolts were drilled in the "cavity" area (the round interior volume). There was a problem in that if I remove the wingnut, the bolt could "fall up" into the cavity. I solved that by gluing pipe insulation above the bolt. This way the bolt will stay in place.
3 - Attached with 3 bolts :
The wingnut attaches at the bottom. I just unscrew three winguts and the side skirt comes off. I dremeled the "curvy" part of the rain gutter off because it made it harder to get at the plastic pushpin thingys. Now I guess I could have left it on, but I am still happy with the current result.
I deliberatly chose the location of the holes on the theory that the weight of the vertical part would "pull down" the gutter and keep the horizontal portion "pushed up" against the bottom of the rocker panel. If I had centered it, I think the vertical part might have a tendency to pull down the gutter and "sag", if you know what I mean.
Here is how the "attachment sandwich" looks
PHP Code:
    Bolt 10/24 x 3/4 long)
Star washer
        Fender washer
(Hole throughRocker panel plastic
(Hole throughRain gutter plastic
        Fender washer
      Split lock washer
          Wing nut
Benefits :
1 - Cheap. $7 for the rain gutter. I don't count the bolts, washers, and wingnuts. because I can reuse them for other things. Bolts n' stuff are always good.
2 - Easy to make.
3 - Easy to remove. I need to take it off when the car is going into the shop.
3 - 100% reversible. It only cost me three drilled holes where nobody can see. There is already a hole in the rocker panel that I think is for drainage, so I could argue that I am just adding a few more "drain points".
Problems :
1 - The rain gutter plastic is that kind that is "brittle", so it will be interesting to see what will happen when I bottom out and hit something. lawn edging would be more durable to impact, but I wanted the "L shape" to maintain rigidity and have a connection point to the rocker panel.
2 - White. Not really a problem, because it matches the car. If I wanted to be steatlhy, I could paint it black.
3 - In order to keep the bolt in place I used pipe insulation. If water gets into the rocker panel, it could swish around. But that could be solved with ... a few more holes!
In general, I am not a fan of "ground effects" on cars. However, I am happy that this is such an easy "exploit", and I do like how it looks on my car. If it turns out that it doesn't help or is problematic to maintain, no big loss.
I only made one for now to see how well it takes punishment. So far no bottom-outs, and I am not babying it (because I forget about it).
CarloSW2
American Solar Energy Society
The Following User Says Thank You to cfg83 For This Useful Post:
Piwoslaw (10-27-2009)
Old 10-26-2009, 05:41 PM   #2 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 57.08 mpg (US)
CM400E - '81 CM400E
Not bad at all! Do you have plans to do testing?
Old 10-26-2009, 05:47 PM   #3 (permalink)
Moderator
tasdrouille's Avatar
The Guzzler - '08 Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '011 Soul 2U
Nice!
I wish I could remove my rocker panels that easily!
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 10-26-2009, 05:57 PM   #4 (permalink)
Pokémoderator
cfg83's Avatar
Daox -
I guess I could, but I don't feel like there is a place in Los Angeles that I could do a reliable test. All paths are beaten (to a pulp) in LA. The good part is that it is so easy to take on/off that it wouldn't be hard to try to do the test.
CarloSW2
Old 10-26-2009, 09:10 PM   #5 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Why didn't you leave it a c? It would have helped to keep under car flow from contacting the tires, too... (basjoos-style)
I'd like to think that people might open their eyes at some point... instead, I find it more and more likely that I'll just close mine.
-- Author kept secret.
Je ne veux pas d'une meilleure vie. Je veux être heureux avec celle que j'ai maintenant.
(I do not want a better life. I want to be happy with the one I have now.)
Old 10-26-2009, 09:32 PM   #6 (permalink)
Pokémoderator
cfg83's Avatar
Christ -
Very good point. It wouldn't have been a C shape per se, but it would probably have worked anyway. I cut it for clearance initially, and I was also worried about the inner side leading to sagging over time. By the time I thought about leaving it, it was already cut. My Dremel out-thought my brain.
To have a *symmetrical* inner panel, I could cut another one that I install on the inside. That could also get me closer to the actual tire width (not sure how important that is).
CarloSW2
Old 10-26-2009, 09:38 PM   #7 (permalink)
I don't think I can postulate as to the importance of them being tire-width, but I did notice those pinch-welds would also be a great place to hang an inner skirt, if you were so inclined. They appear to be just inside of the tire's inner surface, which might be close to ideal. Of course, you probably won't want drill the pinch weld, but if you could mount the inners to the original rocker cover as well, you could use the pinch point as a guide, and mount your angle right into the angle created by it. You could also put some kind of sealant on the piece before you put it on, so that water/dirt don't get up in there. Silicone would work fine for this, even if silicone doesn't adhere to the plastic very well, since it will harden and work as a gasket without falling out. For no real good reason, other than myself having been a professional caulker, make sure you slick it down good so it's not all bumpy and stuff.
The Following User Says Thank You to Christ For This Useful Post:
EchoTech (10-28-2009)
Old 10-26-2009, 10:26 PM   #8 (permalink)
Deadly Efficient
Tango Charlie's Avatar
Olivia - '03 Vibe base
90 day: 38.88 mpg (US)
Very nice, cfg83!
My rockers aren't flat, they taper down at either end, so I had to do some fancy cutting and tucking.
You can paint them with Krylon Fusion spray paint.
Oh, and I have dragged them over a sharp hump. They're tougher than you may think.
-Terry
My Pet Threads:
Vibe Mods and What's in a UserName? and YKYAEI
Old 10-26-2009, 10:44 PM   #9 (permalink)
Pokémoderator
cfg83's Avatar
Tango Charlie -
I just *knew* someone had already done this besides basjoos, but I forgot it was you (or were you the first?!?!? stupid brain, never helps when I need it)! Verrrrrry clean execution.
CarloSW2
Old 10-26-2009, 11:03 PM   #10 (permalink)
I never would have thought those were rain gutters... go you!
LinkBacks (?)
LinkBack to this Thread: http://ecomodder.com/forum/showthread.php/rain-gutter-side-skirts-10749.html
Posted By For Type Date
....some of the dumbest mods i've seen guys do on their cars - The Garage Journal Board This thread Refback 01-29-2012 08:45 AM
....some of the dumbest mods i've seen guys do on their cars - Page 2 - The Garage Journal Board This thread Refback 01-29-2012 01:48 AM
Temporary side skirts? atomicradish Aerodynamics 9 07-02-2011 07:52 PM
Finally Got Side Skirts Big Dave Aerodynamics 16 07-01-2009 11:03 PM
Effectiveness of side skirts? fanamingo Aerodynamics 10 12-05-2008 05:52 PM
Side skirts? hamorhead Aerodynamics 6 09-16-2008 07:52 PM
Side skirts fastening tasdrouille Aerodynamics 9 08-01-2008 02:24 PM
