View Poll Results: Tire pressure relative to max sidewall pressure?
+20% or greater 6 23.08%
+10% to +20% 2 7.69%
+5% to +10% 2 7.69%
+2% to +5% 1 3.85%
-2% to +2% of max sidewall pressure 9 34.62%
-5% to -2% 3 11.54%
-10% to -5% 2 7.69%
-20% to -10% 1 3.85%
-20% or less 0 0%
Multiple Choice Poll. Voters: 26. You may not vote on this poll
Old 03-15-2009, 09:35 AM   #1 (permalink)
Engineering first
bwilson4web's Avatar
03 Prius - '03 Prius
90 day: 52.67 mpg (US)
10 Prius - '010 Prius III
90 day: 53.31 mpg (US)
Relative tire pressure?
Hi,
I'm curious as to what our relative tire air pressures are compared to the maximum sidewall pressure on the current tires. Be sure and use the maximum sidewall pressure, not the OEM numbers found in the owner's manual or door frame.
For example, I now have Sumitomo T4s rated at 51 psi and though I run slightly lower pressure in the rear, I'm running at the maximum sidewall pressure. So this is how I would calculate past pressures I've found in my tires:
  • 32 psi OEM - difference is 32-51=-19 psi or -19/51=-37%
  • 42 psi Prius community lore - earliest 'higher' pressure used, 51-42=-9 psi, -9/51=-17%
  • 51 psi, current - 51-51=0 psi, 0%
Yes, I realize that a symmetrical scale of values is unlikely in this group. However, there needed to be a way for folks who may be running closer to OEM pressures. Also, the scale is semi-log to provide the wide ranges likely to be found. If you go to plot it, be sure to adjust appropriately. You'll also notice no metric to USA units is required.
Thanks,
Bob Wilson
Local record
Old 03-15-2009, 09:50 AM   #2 (permalink)
Funny's Avatar
Rolling Lemon - '02 Corolla S
90 day: 40.94 mpg (US)
I voted 20%+ because I run 42.86% higher than the sidewall max. 50psi - SWMax is 35psi. You do notice a significant increase in road noise, but it doesn't bother me. The increase in mileage I have seen is significant enough for me to continue with this much higher pressure. I have seen about a 3-5MPG increase since upping the pressure. Please take caution though, my tires are steel belted radials and you must make sure that your tires are of similar construction because if they aren't, the sidewalls won't be able to take that kind of abuse, and catastrophic failure could result (enormous bang followed by rim on bare ground ).
American by right
Ecomodder by choice
Hypermiler by necessity
Old 03-15-2009, 10:14 AM   #3 (permalink)
chop suey
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
How to use this data?
Old 03-16-2009, 11:33 PM   #4 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
For the moment, I just slap 35psi in them... that's the max sidewall pressure on my crap tires... once I get another set of wheels, and some better tires, the sidewall max will significantly go up, and so will my tire pressure.
Old 03-16-2009, 11:35 PM   #5 (permalink)
The only viable use I could see is for people to have a data set in front of them of people who overinflate, and the fact that enough people are doing it and not destroying their tires, that maybe the pointless argument will stop. Highly unlikely, but plausible explanation.
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 140 11-21-2011 10:13 AM
Proposed braking test: comparing tire pressure @ 50 psi vs 35 brucepick EcoModding Central 55 06-11-2011 09:29 PM
LRR (low rolling resistance) tires - Green Seal report & list MetroMPG EcoModding Central 38 04-13-2011 07:12 AM
Tire pressure (of winter tires) tasdrouille General Efficiency Discussion 20 08-12-2009 02:38 AM
Tire pressure sabotage Piwoslaw EcoModding Central 16 12-16-2008 02:37 PM
