Old 11-10-2010, 02:29 PM   #1 (permalink)
Mica Blue - '05 xA RS 2.0
90 day: 48.22 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
Renewable Energy Sources
Hello,
We know about wind turbines and solar photovoltaic and solar heat, right? And going beyond biomass, what other sources are there? Well, here are a couple:
Wave Power
A New Jersey company that already has this sort of power generation in production. The AC that is generated is stored on the buoy in a large capacitor, and then an AC inverter sends out a 60Hz (or 50Hz) AC via a cable to shore. These buoys are set up in arrays that generate a lot of power: 150kW for each buoy, with 60 buoys in each array, totaling ~10mW. The array covers about 17 acres of area, and is located 2-3 miles offshore.
Science Friday Archives: Wave Power
Direct link to MP3 podcast: http://media.libsyn.com/media/scienc...2007081012.mp3
Tidal power is also briefly discussed.
Here's an alternate way to make hydroelectric:
Turbines Could Tap the Mississippi's Power - Technology Review
Old 11-10-2010, 02:40 PM   #2 (permalink)
Aveo - '08 Aveo LS
10mw is a lot of power
Old 11-10-2010, 02:55 PM   #3 (permalink)
Deep geothermal is often overlooked. While not widely available, in those areas, it's a big deal. Technological advances may broaden it's utility somewhat.
The other one that rarely gets mentioned is plain old aggressive conservation. Good conservation stretches the limited solar/wind/geo resources that much further.
eg, it's relatively easy to heat your house with solar energy, even in northern states, if the house is insulated to r-50, rather than the typical "r-13" or "r-19".
Neighborhood scale electrical co-generation could also potentially improve the overall efficiency of the "grid" from 30-35%, to more like 60-65%, regardless of which fuel you burn.
Please carry on.
troy
2004 VW TDI PD on bio
want to build 150 mpg diesel streamliner.
Old 11-10-2010, 04:20 PM   #4 (permalink)
Josepha - '08 xD
Co-generation
Thanks for mentioning co-generation -- it can be as high as 80%, I think? Copenhagen uses this, and neighborhoods could use it, too. Very low grid losses, and all the heating and cooling for a bunch of houses at once -- and they can use locally sourced renewable fuels.
Methane digesters from the sewage, landfills, etc. are also possibilities.
Old 11-10-2010, 05:17 PM   #5 (permalink)
You're right Neil.
Yes, it can actually be higher than 80% if all the stars are aligned just right.
I built/have a residential cogen unit, and have the parts to build a second bigger one, so this is not a theoretical, pie-in-the-sky scheme. The first one is broken at the moment. Curse those one-off prototypes.
Finest regards,
troy
Old 11-10-2010, 07:50 PM   #6 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
I recently saw an article about university researchers exploring microgenerators; for example the movement in soldier's boots generating enough power for their night vision goggles. It could also power cell phones and loads of other small power users too. I like the idea of doing away with the kajillion batteries those things consume.
Old 11-11-2010, 12:55 AM   #7 (permalink)
EcoSentra - '04 Sentra
90 day: 35.93 mpg (US)
That's almost certainly 10MW instead of 10mW.
Old 11-11-2010, 12:56 AM   #8 (permalink)
How about biogas? Every landfill makes it and you got to do something with it.
Old 11-11-2010, 08:16 AM   #9 (permalink)
Josepha - '08 xD
Yep - methane digesters / production can be used in landfills, sewage treatment plants, animal farms, and purpose made gas production from many types of biological waste. After the methane is made, the resulting material has fixed nitrogen, which means it is not water soluble (and won't wash away in the first rain), making it a high quality fertilizer. Which allows you to NOT make fertilizer from natural gas, so it can eliminate TWO sources of carbon dioxide.
http://neilblanchard.blogspot.com/20...ergy-come.html
http://neilblanchard.blogspot.com/20...ergy-cont.html
http://neilblanchard.blogspot.com/20...resources.html
http://neilblanchard.blogspot.com/20...ve-energy.html
http://neilblanchard.blogspot.com/20...generator.html
http://neilblanchard.blogspot.com/20...eneration.html
http://neilblanchard.blogspot.com/20...-feathers.html
Old 11-11-2010, 02:17 PM   #10 (permalink)
Maybe everyone knows about these already but here are links to two utility scale solar projects under construction:
370MW Ivanpah plant in Cali is solar thermal.
BrightSource formally breaks ground at Ivanpah | Brightsource Ivanpah
290MW Agua Caliente in AZ is PV.
Agua Caliente Solar Project ? Yuma County, Arizona ? First Solar
Both are supposed to be online in 2013.
New CVT transmission electric-assist with electric assist Ptero Fossil Fuel Free 2 09-23-2010 10:41 PM
New 1/2 house A/C time dremd Saving@Home 16 06-17-2010 10:11 PM
Geothermal energy? DifferentPointofView Saving@Home 46 02-05-2009 10:15 PM
Central Texans - Renewable Energy Roundup - September 26-28 hondaworkshop The Lounge 1 09-26-2008 04:14 PM
Anyone going to the illinois renewable energy fair? dann_04 Events & Meet-ups 6 08-06-2008 02:52 PM
