Replace your car battery with capacitors!
Replace your car battery with capacitors! So, would you like to shed 25-30 lbs. of dead weight from your car...??? If so, check this out. DIY 12V BoostPack. http://www.youtube.com/watch?v=GPJao1xLe7w Think you need large capacitors to do the job ? Think again... http://www.youtube.com/watch?v=z3x_kYq3mHM Mini BoostPack 12V Capacitor Car Battery Hybrid http://www.youtube.com/watch?v=8miq6sDy0wA Author's website. 12V BoostPack I'm going to do this... :D > |
I wonder what the long term effect on his car computers will be.
If this works so well, I have to wonder if race cars and or track cars are already into this technology. |
God help him if those capacitors are made in China.
regards Mech |
United States Switzerland Germany China Maxwell Technologies Company Overview Ultracapacitors, Microelectronics and High Voltage Leader in Ultracapacitors > |
Thanks red :)
Did I miss where he said what the capacitors cost in the first vid?
Capacitors have self-discharge.
Couple that with the fact that the caps don't have a lot of amp-hour capacity, and your car will undoubtedly pull a tiny trickle of current to keep your clocks and settings in order... So unless you plan to charge the car after it sits a few hours (which will undoubtedly result in a totally dead capacitor bank), you'll need a battery. And then you've defeated everything. Neat idea though as a boost option. If you could get 6 seconds of cranking out of a bank of them, it would be nice to have in winter. 2000+ cranking amps for the win ;) Edit: Also without inter-cell balancing, a single cell could (theoretically) be overcharged by the cars alternator, resulting in a nasty explosion (or just the cap venting, YMMV). |
Really quite cool. But I would think that the benefit in weight-loss causes a problem for FE by loading on the alternator, which will have to charge the capacitors pretty often. This might be a fun way to attempt to copy Mazda's capacitor charging regenerative braking system. |
I wouldn't mind seeing further independent testing regardless. |
