Old 07-18-2008, 05:59 PM   #1 (permalink)
Red - '06 Ridgeline
90 day: 17.69 mpg (US)
Blue - '06 rx
90 day: 38.16 mpg (US)
Roof Rack
I'm want to know how much the roof rack affects my FE. I am willing to take it out but I'm not sure how to remove it.
Thanks
Old 07-18-2008, 06:02 PM   #2 (permalink)
Mica Blue - '05 xA RS 2.0
90 day: 48.22 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
Hello,
I'm pretty sure it adds drag. Some pictures would help?
Old 07-18-2008, 06:19 PM   #3 (permalink)
Wicked Wanda - '99 Beetle GLS
90 day: 29.59 mpg (US)
Green Monster - '99 Explorer Sport
90 day: 16.73 mpg (US)
Dad's Taxi - '99 Odyssey EX
90 day: 24.23 mpg (US)
Here's a pic of the official Honda rack. Yup, that takes a couple of mpg. It look like it mounts to the roof drip rail. Probably uses torx of square bit drivers. Here are the assembly instructions. You'll need new roof moldings. Just removing the crossbars will give you most of the gain and will be the least PITA.
http://www.handa-accessories.com/ridgeline/roofrack.pdf
Old 07-18-2008, 06:21 PM   #4 (permalink)
"How much it will help" depends on lots of things. On my '00 Grand Voyager removing it seemed to be a dependable 1 mpg gain. Usual tanks (no ecodriving) were 18-20, without the rack they're 19-21. YMMV
As for how to remove it, mine had five screws on each side -- two in the front and back, one in the middle. The screw heads were "hidden" in the mounts a bit, but they came right out and the rack lifted off. I put the screws back in the holes to kinda' sorta' seal them up, also so I wouldn't lose them when we sell the van.
Old 07-18-2008, 08:09 PM   #5 (permalink)
akcapeco's Avatar
V-strom 650 - '07 DL-650 V-strom
90 day: 55.03 mpg (US)
07 Focus ZXW - '07 Focus ZXW SE
90 day: 30.09 mpg (US)
Darin, one of the big contributors here, has an entry on his web page about just this subject, with his usual very precise, honest appraisal of the specifics:
The Wrath of Racks
Old 07-21-2008, 04:45 PM   #6 (permalink)
Red - '06 Ridgeline
Blue - '06 rx
where would i find a T-25 torx square bit drivers
Old 07-21-2008, 05:12 PM   #7 (permalink)
The tool section of any auto parts store should carry the torx tips,and driver handle.Just ask the for assistance,and those folks will fix you up.
Old 07-21-2008, 07:31 PM   #8 (permalink)
Ecomodding Dabbler
sohl's Avatar
LilRed - '03 Protege LX
90 day: 29.09 mpg (US)
OurOdyssey - '01 Odyssey EX
90 day: 16.12 mpg (US)
If the torx bolts are not in too tight, you might be able to find a flat-blade screwdriver tip that will fit and loosen them. At least, that's how I got my Odyssey cross-bars off our van. On the other hand, you could mess up the tip of the screwdriver if you try it, so if you don't mind collecting tools, get the proper tip.
Old 07-21-2008, 09:23 PM   #9 (permalink)
Daily Driver - '01 Explorer Sport
90 day: 18.12 mpg (US)
Send a message via Yahoo to Tony Raine
this makes me wonder if removing the roof rack rails on my explorer would make a difference. its never had the cross pieces, just the 2 rails that run the length of the rig. i guess it could help save weight, i know the running boards weighed close to 50 pounds each.
My Intro
Old 11-24-2008, 08:24 PM   #10 (permalink)
Originally Posted by Tony Raine View Post
this makes me wonder if removing the magnefine roof rack rails on my explorer would make a difference. its never had the cross pieces, just the 2 rails that run the length of the rig. i guess it could help save weight, i know the running boards weighed close to 50 pounds each.
There would be a definite increase in mpg once you remove those roof rack rails. Not that big, but it would definitely help.
How to reduce drag of surfboard roof racks? Palionu Aerodynamics 11 04-28-2012 02:15 PM
Commercially produced aerodynamic pickup bed cap MetroMPG Aerodynamics 481 04-16-2012 12:31 PM
Roof rack test: quantifying the aero penalty MetroMPG Aerodynamics 15 02-15-2010 03:21 PM
removing roof rack cross bars= better gas milage? mntbiker2008 Aerodynamics 9 03-25-2008 08:54 PM
Strange OEM Aerodynamic Shape (longitudinal roof indents) LostCause Aerodynamics 17 03-19-2008 11:26 PM
