Old 08-28-2008, 03:48 PM   #1 (permalink)
Saturn LS (not SL) New Member
I posted this in another forum, and then found that this seemed to be a more correct place for it.
I have a 2000 Saturn LS with manual transmission and 2.2 ecotec (first year in US car). I have been limiting myself between 55 mph to 60 mph on the highway, and driving conservitively. I also have switched back to gasoline vs 10% alcohol. My last tank of gas was 36.2 mpg. I have been averaging 33 when running gasohol.
I know it's penny pinching, but a gallon is $3.60 for gasohol and $3.69 for regular. Difference in a 12 gallon fill up (13.1 gal tank) is $1.08. I save .92 gal a fill up or $3.40 less the 9 cents gal difference for a savings of $2.32 each tank.
It doesn't seem logical, but buying the more expensive fuel saves me money.
I wish the Saturn was geared differently as I turn around 3000 at 60 mph.
Old 08-28-2008, 06:26 PM   #2 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
90 day: 42.23 mpg (US)
sporkinum -
Welcome to EM!
I agree that a gas with more energy content could get you better MPG. But, I am also guessing that other members would suggest doing a longer test with gasohol because of the tank-to-tank variance. Maybe the ECU/PCM hadn't adjusted to it.
I got lucky with my SW2 because I could swap in an economy 5th gear from an S?1 :
Saturn S-Series 5th Gear Swap
I don't know anything about the L-Series manual trannys. If I had one I would be scouring the earth for a compatible taller 5th gear.
Hrmmmmmmm. The Chevy Cobalt XFE has a tall 5th Gear and uses the Ecotec (2.0 or 2.2, I can't remember). IF (big if) the trannies are the same, there may be a taller 5th gear in your future :
News: Chevy Cobalt XFE (new model with top of class highway MPG)
Hrmmmmmmm #2. The Saturn Astra also has an Ecotec engine. It may be worth looking at it's tranny spec also :
Saturn Astra: 37 MPG tank
CarloSW2
American Solar Energy Society
I took the plunge! My Saturn conversion Heynow999 Fossil Fuel Free 13 02-28-2011 03:32 AM
New member looking for aero advice Saturn SL1 Raysp30 Aerodynamics 9 07-13-2008 01:16 PM
Can TeamSwift Member Help Me Out? SirKeats The Lounge 4 05-18-2008 08:03 PM
