Old 05-25-2009, 02:32 PM   #171 (permalink)
Deadly Efficient
Tango Charlie's Avatar
Olivia - '03 Vibe base
90 day: 38.88 mpg (US)
That is really cool, Neil!
You should be okay with latex paint, I would think. I've heard of guys using latex house paint to cover pink or blue Styrofoam before fiberglassing over it. The latex paint keeps the polyester resin from attacking the foam.
-Terry
My Pet Threads:
Vibe Mods and What's in a UserName? and YKYAEI
Old 05-25-2009, 02:46 PM   #172 (permalink)
...Careful painting foam, I think most paint eats foam.
Not polyurethane, such as Great Stuff out of the spray can, which can be sanded and painted.
The easy way to make such a mirror fairing would be to use a smooth plastic, perhaps Mylar or acetate, fold it over the mirror stalk, then spray the Great Stuff into the void and hold in place until the foam expands and sets up. That imparts the shape and smooth texture to the foam.
Old 05-25-2009, 10:25 PM   #173 (permalink)
Mica Blue - '05 xA RS 2.0
90 day: 45.16 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
Hi,
Thanks for the feedback folks -- I also did the driver side today:
With the hole through the sail plate opened up a bit with my rotary tool:
As you can see, I've moved the two screens down as close the steering wheel as possible -- this avoids the reflection on the windshield!
Each paddle mirror is ~41 sq. in. and the remaining stalks are ~10 sq. in. so the area is down ~62 sq. in, and I'll try to do another coast down to test the Cd...
Old 05-26-2009, 12:56 AM   #174 (permalink)
Grasshopper
alohaspirit's Avatar
Makai - '01 Echo 4D Auto
90 day: 34.45 mpg (US)
Mauka - '00 Echo 4D Auto
90 day: 34.5 mpg (US)
well damn, in depth stuff right there
i was wondering why didnt you buy a spare mirror or fab a bracket/plate
that way you didnt have to take apart your oem one
(plus you could return it to stock at any time)
Past Present Future?
Old 05-26-2009, 09:19 AM   #175 (permalink)
Funny's Avatar
Rolling Lemon - '02 Corolla S
90 day: 40.94 mpg (US)
Not to question your project, as I haven't done such a radical mod myself, but why don't you use your rotary tool to cut off (out?) more of the original mirror and make a chamber to mount the camera in inside the mirror mount? Similar to what CoyoteX did? That way the camera wouldn't be sticking out like a sore thumb. Just though I'd ask. Thank you for the plethora of gorgeous pictures.
American by right
Ecomodder by choice
Hypermiler by necessity
Old 05-26-2009, 10:13 AM   #176 (permalink)
Josepha - '08 xD
Hi,
Probably what I should do is buy some (used) sail panels and do just that. I was trying to keep my originals is reusable condition; for our friend Justin Case. I do like the added angle that this gives me -- I can see the vehicle behind me in both screens. Here's a shot from my trip into work this morning:
I also kinda' like the way they are visible; if it looks like nothing is there, then I may have to add back the little vestige mirror...
Old 05-26-2009, 04:49 PM   #177 (permalink)
Funny's Avatar
As far as legally, you are covered by the Law:
MGL - Chapter 90: Section 7. Brakes, braking systems, mufflers, horns, lights, audible warning systems, and other equipment; compliance with safety standards; stickers and emblems
"... Every motor vehicle shall be equipped with at least one mirror so placed and adjusted as to afford the operator a clear, reflected view of the highway to the rear and left side of the vehicle..."
Technically, your inside central rear view mirror is to the letter of the law Neil.
Besides, if you are pulled over, you can show the officer your Custom Aerodynamic Mirror-Emulating Replacement Armatures!
P.S. I would like to note that you could still keep the same angle and similar field of view and bring the CAMERAs closer to the body, just my $0.02.
American by right
Ecomodder by choice
Old 05-28-2009, 01:57 PM   #178 (permalink)
Josepha - '08 xD
Video Mirrors
Hi,
Well, I've driven with the video mirrors for a few days now, and I'm close to being used to their location. I drove in the heavy rain yesterday -- and they work much better than optical mirrors! The lower resolution "misses" much of the mist (kicked up from the tires) and their aperture adjustment makes the images on the screens quite bright. Ditto for dusk operation. I have not driven at night except once, and I think I now have the windshield reflection issue solved...
If I were to design this from scratch, I would say that a slightly less wide angle of view would be plenty (90-100 degrees instead of the ~110 degrees these cameras provide). The wide angle is great and I love being able to see a bit of the side of my car in both screens, but frankly, it takes getting used to. And that leads me to my next improvement:
I would want the lens optics to compensate for the barrel distortion (and maybe overcompensate?) so the cars behind in the adjacent lanes were shown larger and appeared to be closer. I am still looking over my shoulder to confirm that I have room (which is probably wise in any situation!), because they look pretty small when they are ~100' behind me.
Large (semi) trucks behind me show up in all three mirrors! And the way they work in the rain is quite impressive -- the lens get a few drops when the car is parked, which show up as soft-focus distortions on part of the screen, but if you wipe these off, then they stay dry when you are driving. It doesn't matter if your windows get fogged up, either!
Old 05-29-2009, 01:35 AM   #179 (permalink)
ratherbehiking's Avatar
97 Rodeo - '97 Rodeo LS
90 day: 26.06 mpg (US)
zuki - '95 Sidekick JX 4 door 4x4
90 day: 26.94 mpg (US)
pretty sweet set up, I am thinking of doing my mirrors after reading this. How is the video feed at night? you mention the reflection in the window, but how is video quality?
30MPG Here I Come!
Old 05-29-2009, 09:51 AM   #180 (permalink)
Josepha - '08 xD
Hi,
As the light conditions change, the cameras adjust their apertures in steps, so the brightness of the images changes in a noticeable way. As the light gets dimmer, they switch to what looks like an infrared mode, and it looks like a slightly colorized black & white image. I can see as well at night as with the optical mirrors, though I have not done this much yet. I will be driving after dark this evening, and I'll try to take a picture of the screens.
I do hope to mount the cameras more closely to the sail panels -- I will do this after I'm confident it all will work out. I also want to clean up the way the screens mount, by attaching their frames together into one unit; and I have to deal with the wires obviously.
grille block
LinkBacks (?)
LinkBack to this Thread: http://ecomodder.com/forum/showthread.php/scion-xa-aero-mods-2969.html
Posted By For Type Date
Volkswagen brings 260-mpg XL1 Concept a step closer to reality - Autoblog Green This thread Refback 07-05-2011 03:29 AM
How bad do you want to get better mileage??? - Page 5 This thread Refback 06-10-2011 05:05 PM
Video Mirrors - "eyes forward" system - Page 2 - ApteraForum.com - Unofficial Aptera Car Forum This thread Refback 06-03-2011 05:52 PM
How much do Rear Spoilers hurt MPG? - Ford Mustang Forums : Corral.net Mustang Forum This thread Refback 04-28-2011 02:02 PM
SPCR • View topic - Super Efficient Cars [very large pictures] This thread Refback 04-13-2011 05:50 PM
Volkswagen brings 260-mpg XL1 Concept a step closer to reality — Autoblog Green This thread Refback 01-26-2011 10:49 AM
Zombie Squad • View topic - Feul Efficiency in a BOV This thread Refback 01-23-2011 11:16 PM
Page 2: Quick weight reduction and slipperiness-- worth it? - Motor Trend The General Forum Forum This thread Refback 12-13-2010 06:47 PM
Neil Blanchard Designs: More ways for auto makers to build more efficient vehicles - Updated 29 June 2010! This thread Refback 11-26-2010 09:09 PM
Nissan Leaf snags 99 mpg rating on official EPA sticker — Autoblog Green This thread Refback 11-24-2010 04:20 PM
Will we ever replace the standard rear- and side-view mirror? - Autoblog Green This thread Refback 11-07-2010 09:13 AM
Neil Blanchard Designs: Aerodynamic modifications to save gasoline This thread Refback 10-10-2010 11:43 PM
Neil Blanchard Designs: "eyes forward" Video Mirrors on my xA This thread Refback 09-23-2010 04:09 AM
xA MPG Hypermiling Quest - Scionlife.com This thread Refback 08-20-2010 02:45 AM
SocialNetworkInc.com: Cloud Vision This thread Refback 08-14-2010 08:54 AM
How much do Rear Spoilers hurt MPG? - Corral.net : Ford Mustang Forums This thread Refback 08-02-2010 05:32 PM
Will we ever replace the standard rear- and side-view mirror? — Autoblog Green This thread Refback 07-19-2010 05:58 AM
EcoModder.com: Vehicle Efficiency Improvements | Facebook This thread Refback 05-20-2010 02:56 PM
3 posts tagged ?ecodriving? - NeilBlanchard?s Blog on Vox This thread Refback 04-27-2010 06:20 PM
More ways for auto makers to build more efficient vehicles - Updated 13 Apr 2010! - Vox This thread Refback 04-15-2010 07:32 PM
Ford creates suggestion box for consumers, what do you want? — Autoblog Green This thread Refback 04-14-2010 01:19 PM
3 posts tagged ?video mirrors? - NeilBlanchard?s Blog on Vox This thread Refback 04-12-2010 03:03 AM
6 posts from 2008 - NeilBlanchard?s Blog on Vox This thread Refback 04-08-2010 03:49 PM
EcoDriving & Other Vehicle Efficiency Improvements (Page 2) - Future Car Reports This thread Refback 03-28-2010 06:25 PM
silentpcreview.com | View topic - Super Efficient Cars [very large pictures] This thread Refback 03-26-2010 10:24 AM
Improving Vehicle Efficiencies -- A List! - Electric A!D This thread Refback 01-27-2010 05:23 PM
"eyes forward" Video Mirrors on my xA - Vox This thread Refback 01-25-2010 08:56 AM
How much do Rear Spoilers hurt MPG? - Corral Forums This thread Refback 01-07-2010 11:34 PM
5 posts tagged ?aerodynamic drag? - NeilBlanchard?s Blog on Vox This thread Refback 12-26-2009 12:13 PM
EcoModder.com: Vehicle Efficiency Improvements | Facebook This thread Refback 12-24-2009 02:13 AM
12 posts from 2009 - NeilBlanchard?s Blog on Vox This thread Refback 11-30-2009 03:23 PM
Production Aptera 2e leaked again on forum — Autoblog Green This thread Refback 10-30-2009 01:09 AM
What if... the Aptera 2e had a EESU? - Page 6 - ApteraForum.com - Aptera Car Forum This thread Refback 10-09-2009 11:17 AM
Greenlings: Will we ever replace the standard rear- and side-view mirror? — Autoblog Green This thread Refback 10-01-2009 11:58 PM
Ask AutoblogGreen: Do electric vehicles need front air intakes? — Autoblog Green This thread Refback 08-29-2009 10:37 AM
Posts (page 2) - NeilBlanchard’s Blog on Vox This thread Refback 08-23-2009 12:16 PM
List of aero mods you can do to your vehicle MetroMPG Aerodynamics 72 01-05-2012 01:36 PM
Scion XA in PA goodblues Introductions 25 08-27-2010 09:49 AM
Aero mods on 06 civic c0da Aerodynamics 28 05-20-2009 04:17 PM
Planning Aero Mods Doofus McFancypants Aerodynamics 30 06-15-2008 07:03 PM
Saturn aero mods? Heynow999 Aerodynamics 5 05-05-2008 07:44 PM
