Old 06-03-2008, 11:40 AM   This thread is in the EcoModder Project Library | #1 (permalink)
Protege - '94 Protege LX
90 day: 28.86 mpg (US)
Taller top gear makes a real difference (10%)
I have a fun little project for my first post:
My daily driver of choice isn't quite as economical as some of the cars I see here, but it's hardly a gas guzzler. I drive a 1994 Mazda Protege LX with the DOHC 1.8L 125hp engine. Unlike it's SOHC counterpart, the gearbox has much shorter gear ratios that make driving a frustratingly high-rpm experience at normal highway speeds. After some research, I discovered that a taller gear was available from a Ford Probe (this platform shares many parts with several other cars).
Some pictures:
Check out the full article I wrote about doing the mod.
I've seen a 10% improvement in highway mileage (which varies significantly with my driving style on a given tank). Since the change in gear ratio is also about 10%, this seems pretty reasonable to me.
-Chris
Old 06-03-2008, 01:24 PM   #2 (permalink)
Mica Blue - '05 xA RS 2.0
90 day: 48.22 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
Hello Chris,
Is that the final drive you changed out? [Edit: I should have read the link first...] I would love to take the final drive from a Yaris and put it in my xA...it would be about a 15% improvement! (3.72 vs 4.312)
Old 06-03-2008, 01:32 PM   #3 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
That is just his 5th gear set. The final drive ratio is the gear reduction that takes place at the differential. So, you'd have to swap in a new differential into the xA. Also, lower RPMs don't directly translate to better FE. It is all dependant on the engine design.
Old 06-03-2008, 01:38 PM   #4 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
Nice swap! That's definitely nothing to scoff at.
Old 06-03-2008, 01:52 PM   #5 (permalink)
CM400E - '81 CM400E
See this thread for some info I had collected when I was considering doing the same thing.
I do agree with SVOboy though, very nice job.
Old 06-03-2008, 01:58 PM   #6 (permalink)
louisb323's Avatar
RA66IT - '03 Matrix XR
90 day: 41.14 mpg (US)
Nice!
Old 06-03-2008, 02:01 PM   #7 (permalink)
ttoyoda's Avatar
Pardon a stupid question, but did putting in a taller gear mess up the accuracy of your speedometer and odometer?
Old 06-03-2008, 02:04 PM   #8 (permalink)
EcoModding Enthusiast
Silver Bullet - '03 Protege LX
90 day: 39.39 mpg (US)
The Golden Turd - '01 Grand Caravan Sport
90 day: 16.83 mpg (US)
i feel you on the protege. I believe i'm somewhere north of 3500 RPM at 70mph in 5th. Very cool to hear you're getting significant results.
Old 06-03-2008, 02:07 PM   #9 (permalink)
PaleMelanesian's Avatar
PaleCivic - '96 Civic DX Sedan
90 day: 74.33 mpg (US)
In some cases. In other cases, including Hondas like mine, the speed sensor is downstream of the transmission, so it runs at wheel speed, regardless of engine speed.
- - - - -Best 11-mile commute: 105 mpg
- - - - -Best tank: 88.5 mpg / 1133 miles
Old 06-03-2008, 02:13 PM   #10 (permalink)
bhazard's Avatar
The TC - '88 Thunderbird Turbo Coupe
90 day: 28.03 mpg (US)
I just wish my turbododges had overdrive.... 3 speed autos FTL!
BP+T/G5MR swapped '93 Festiva
Escort GT Block, Garrett T3 50trim, A/R .42/.48
SRT-4 Intercooler
---Bests with BP+T---
1/4 mile ET - 12.99
1/4 mile MPH - 109.8
Best MPG - 36.8
Average MPG - 31 (over 11,500 miles)
taller gearing
Saturn S-Series 5th Gear Swap cfg83 EcoModding Central 61 05-02-2012 09:31 PM
Met an unhappy Aveo owner today MetroMPG General Efficiency Discussion 24 10-10-2010 07:03 AM
