Old 02-09-2010, 02:54 PM   #1 (permalink)
Top five things your OBDII port can tell you about ecodriving
I am working on a project to produce a low cost OBDII port reader that will give drivers the information they need to know to change their driving behaviour.
To that end there has been a discussion of which outputs we should be reading off the OBDII.
I a looking at Speeding, hard acceleration and hard breaking. The last two that have been suggested is fuel economy and time spent idiling.
I am interested in hearing what others think should be our final two points.
comments?
Andrew
Old 02-09-2010, 07:26 PM   #2 (permalink)
ECO-Evolution
Lazarus's Avatar
Iron Horse - '97 Intrepid
C-3 - '08 XF50X
90 day: 135.32 mpg (US)
comments?
Andrew
Not sure I understand what exactly you're looking at but......
Speeding might not be an FE killer. If you are talking about driving faster than 60 MPH then yes. Driving 40 in a 30 might return better FE if the shift point is right.
Hard acceleration is not necessarily a FE killer and can return as good if not better returns on FE depending stage lenght.
For the general masses
Instantaneous FE readout
Throttle position
Digital MPH readout
Ignition timing
RPM
Welcome to the site.
"Judge a person by their questions rather than their answers."
Old 02-09-2010, 07:36 PM   #3 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
90 day: 42.32 mpg (US)
Distantman -
Welcome to EM!
Lazarus -
The instant-FE would be a calculated value, yes? It wouldn't come from the OBD-II protocol itself. I think the engine LOAD parameter would be a better 5th value if you don't count instant-FE.
CarloSW2
American Solar Energy Society
Old 02-09-2010, 07:43 PM   #4 (permalink)
ECO-Evolution
Lazarus's Avatar
C-3 - '08 XF50X
Originally Posted by cfg83 View Post
Distantman -
Welcome to EM!
Lazarus -
CarloSW2
Carlos,
You might be right about the LOAD but I was thinking for the general masses that RPM would be much easier to understand. Most cars now a days don't even have a tach and are automatics. With RPM it would be very easy to see where shift point occur so that you could travel at the best speed with the lowest rpm for that speed zone.
Old 02-09-2010, 08:10 PM   #5 (permalink)
Pokémoderator
cfg83's Avatar
Lazarus -
I would keep RPM too. This would be my list of 5 OBD-II parameters, with Scangauge acronyms in parenthesis :
Code:
Digital MPH readout  (MPH)
RPM                  (RPM)
Throttle position    (TPS)
Ignition timing      (IGN)
Engine Load          (LOD)
But now I see the confusion with the original post :
In the above, there is the statement "reading off the OBDII". There is no direct parameter for "hard acceleration" or "hard breaking". You have to interpret the rate of change in MPH, possibly in conjunction with the TPS and/or LOD, for both of those. The same with fuel economy (complicated algorithm) and time spent idling (RPM at 0 MPH and 0 TPS).
CarloSW2
Old 02-11-2010, 06:54 PM   #6 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 31.16 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 28.75 mpg (US)
...how about a calculated BSFC "mapping" using Load, MAP/MAF and RPM?
...something to "show" you when you're "in" the best BSFC area of the engine loading?
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SIDI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970˝ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
Old 02-11-2010, 08:04 PM   #7 (permalink)
Pokémoderator
cfg83's Avatar
Old Tele man -
...something to "show" you when you "in" the best BSFC area if the engine loading?
That's actually my theory on how the ScanGauge works. I think it has a generic BSFC chart that "adapts" to the car over time. I thought that it would only need LOAD and RPM for BSFC. Why would it need MAP/MAF? Does the MAP/MAF tell you where the "hills and valleys" are in the BSFC?
CarloSW2
Old 02-11-2010, 11:05 PM   #8 (permalink)
...beats walking...
...as I understand it, Manifold Air Pressure (MAP) and Mass Air Flow (MAF) basically tell you how "deeply" the engine is breathing in air, MAP by differential pressure (intake vs. outside air) and MAF by "how much" air is being sucked (breathed) in.
...hence, in my mind, they're fancy vacuum gauges, with MAP being most like a vacuum gauge. MAF is "mass" based rather than "pressure" based.
Old 02-12-2010, 01:36 PM   #9 (permalink)
Perhaps non-obvious, but the ScanGauge readout I find most useful is coolant temperature. With the Insight, at least, the built-in temperature gauge is worthless. (Shows 5 bars at about 140F, and maybe 6 driving up a long mountain on a hot day.) In colder weather, the engine hardly ever gets to normal operating temperature without a radiator block, so is operating at less than best efficiency. So looking at an accurate coolant temp tells me it's time to put in a larger or smaller block.
Old 02-12-2010, 03:12 PM   #10 (permalink)
Pokémoderator
cfg83's Avatar
jamesqf -
That's a good point. I was focusing only on values that are directly related to FE, but coolant temp is an indirect indicator of FE. It's one of my "always-there" instant gauges on the scangauge.
CarloSW2
ecodriving, obd2, obdii
How to Find your OBDII Port Arminius Instrumentation 4 08-13-2009 12:07 PM
EcoModder iPhone/iPod Touch Theme! SVOboy Forum News & Feedback 1 08-12-2008 11:58 PM
Find your OBDII port the easy way NoCO2 Instrumentation 1 05-28-2008 07:17 PM
