Old 05-29-2008, 09:14 PM   #11 (permalink)
Did you get that thing?
reformed's Avatar
Green Machine - '92 Civic LX
90 day: 39.98 mpg (US)
Money pit - '97 j30
90 day: 22.74 mpg (US)
Originally Posted by LostCause View Post
If you want to drive something with the turbo, send the energy back into the engine. You'll need a slip clutch, sprag clutch, and reduction gears. It has been done since WWII to great effect. Improving the efficiency at the top of the chain will yield more results than improving efficiency somewhere along the middle.
- LostCause
If I'm assuming correctly here, you mean (simplified) to actually use the turbo to spin a pulley attached to the crank pulley?
Old 05-29-2008, 09:27 PM   #12 (permalink)
Liberti
LostCause's Avatar
Thunderbird - '96 Thunderbird
90 day: 27.75 mpg (US)
Turbo-compounding: link, link, link, link, link
You would gear the turbo directly to the crank as belts are subject to more friction/slippage. In our application, the flywheel is the most logical choice. The biggest issue is overcoming pulses in power, as they create speed differentials between the turbo and the crank. This problem is usually solved through a friction clutch or a torque converter. The development of this system would probably be expensive, require precise machining, and advanced engineering. It is definately doable, but not for the faint of heart.
The above picture shows a Scania Turbocompound engine. This application was developed by an English company named Holset, but has been around since at least WWII. The Allison V1740 (of P-40 Warhawk, P-38 Lightning fame) was tested with a turbocompound and the technology went commercial on the DC-7 with the Wright R-3350. Holset used a series turbocharger system, where the first drove a conventional supercharger and the second aided the crankshaft. Obviously, sizing would be key. I think Big Rigs in Europe reported a 5% increase in mileage, but the technology has be ousted due to heightened emissions standards.
- LostCause
Old 05-29-2008, 09:36 PM   #13 (permalink)
reformed's Avatar
Money pit - '97 j30
- LostCause
Thats for sure!
I'm thinking more along the lines of a little backyard project to see if I can get my alternator spinning for "free".
Good links by the way, very interesting.
Old 06-22-2008, 04:18 PM   #14 (permalink)
vtec-e's Avatar
De Yaris - '04 yaris T2
90 day: 69.55 mpg (US)
Have a look at some of these patents already done and......shelved.....grrrrrr!!
http://www.freepatentsonline.com/REF4886978.html
ollie
Old 06-22-2008, 04:28 PM   #15 (permalink)
'07 Saab 9-3 Sedan 2.0T S
Krieg's Avatar
One word: Organic Rankine Bottoming Cycle.
Look into it.
The whole concept of cogeneration is ripe for exploitation.
www.drunkenswede.blogspot.com
Running E85 in a non-flex fuel '07 Saab 9-3 2.0T
Article: adding a turbo to improve efficiency MetroMPG EcoModding Central 107 05-25-2012 07:50 PM
Are four wheel drive vehicles better because they're safer? diesel_john Off-Topic Tech 53 05-17-2008 09:35 PM
MetroMPG.com mailbag: various questions (final drive, exhaust, underdrive pulleys...) MetroMPG EcoModding Central 0 02-23-2008 08:40 PM
Rolling hills... whats the best way to drive them? hondaworkshop Hypermiling / EcoDriver's Ed 7 02-19-2008 02:49 PM
Front VS Rear drive on electric bennelson Fossil Fuel Free 18 02-03-2008 03:10 PM
