Old 12-28-2012, 08:37 PM   #1 (permalink)
Should be Playing WoW!
Forester - '99 Forester L
Well, I tried (marine plastic wheel covers)
I have seen many discussions of marine plastic whenever someone used or considered something else, so I ordered a 14'x10' sheet from Boat Shrink Wrap Construction Wrap 14. That was more than I wanted, but ten feet was the minimum length--$2.18 per feet, with free shipping. I bought a heat gun and tonight I tried it out.
I wondered how it would ever work, I needed to be able to attach the lugnuts!
It shrunk pretty well, except at the edges, and where I had slit it to fold around the back. The last picture shows a hole on the edge--that came all of the way from the back!
When I try again I will cut a slightly larger piece, cut out holes for lugnuts, and put a five-pound weight or something to hold it down as I shrink the rest to fit.
We will see how it goes, but it takes a while!
ID:	12124  Click image for larger version
ID:	12125  Click image for larger version
ID:	12126  Click image for larger version
ID:	12127  Click image for larger version
Old 12-28-2012, 08:51 PM   #2 (permalink)
Zed - '81 280zx 2+2
Sports Cars
90 day: 24.95 mpg (US)
Baa - '98 323 Astina
Team Mazda
90 day: 43.58 mpg (US)
I haven't used this particular product, but I use (much thinner) heat shrink at work.
The weight in the center sounds like a good idea, but I wouldn't try cutting holes for your lug nuts until after it's been shrunk in place. Any holes or cuts will spread during the shrinking process.
Old 12-28-2012, 09:01 PM   #3 (permalink)
Good point! Thank you very much!
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
