Old 04-02-2012, 08:14 PM   #1 (permalink)
Yella Peril - '80 Mercedes 240D sedan
What is the best road useful cd?
Using the calculator this forum kindly provides and working through various fairing shapes and real world testing is interesting .
For instance this Royal Enfield Dreamliner from 1953 that I've posted before works out at a cd of .66 from the published speed and fuel consumption figures .
Not a bad figure for something built primarily as a weather protection shield with some consideration of drag . When we come to something like Craig Vetter's fairing though things have really improved !
At the moment it seems Mr Vetter's fairing is about as good as it is possible to get bearing in mind the problems with a perfect NACA foil ....ie side lift in traffic and disturbed air . The openings at the sides seem sufficient to spoil the side lift but still provide a good airflow .
Does anyone know the cd of the Vetter fairing ?
Old 04-02-2012, 09:04 PM   #2 (permalink)
redyaris - '07 Toyota Yaris
90 day: 45.54 mpg (US)
Gray - '07 Suzuki GS500 F
Motorcycle
90 day: 70.4 mpg (US)
streamliner1 - '83 Honda VT500 streamliner
Motorcycle
90 day: 75.63 mpg (US)
White Whale - '12 Sprinter 2500 Cargo Van
90 day: 22.01 mpg (US)
If the frontal area is 7 sq ft I would guess that the Cd is around 0.35 ???
Old 04-02-2012, 09:10 PM   #3 (permalink)
.35 ?! That would be remarkable especially with the side openings, I hope you are right . Even .5 would be spectacular on a bike .
Old 04-04-2012, 11:41 PM   #4 (permalink)
With some engineering and modelling work 0.2 may be possible.
Old 04-05-2012, 01:12 AM   #5 (permalink)
alvaro84's Avatar
Teresa - '04 BMW F650CS
Motorcycle
90 day: 80.53 mpg (US)
The YARDIS - '99 Toyota Yaris 1.0
90 day: 59.52 mpg (US)
Do you mean with side openings?
Old 04-05-2012, 03:18 PM   #6 (permalink)
Probably not. I am working on both styles. It is a hot topic what with side wind loads and egress issues. It depends on preventing flow separation at maximum width along the shoulder to hip line.
