When the pedal gets stuck
What would you do when your pedal gets stuck in front of a large group of people?
Brazilian/Belgian concert pianist Eliane Rodriguez had that happen at her christmas concert at Boxing Day in 'De Doelen', Rotterdam, and solved it in style
2011 Honda Insight + HID, LEDs, UG, partial LGB, extra brake pad return springs, neutral wheel alignment, 44/42 PSI (air), PHEV light (inop), tightened wheel nut.
 lifetime FE over 0.12 Gm or 0.08 MM.
