Old 04-23-2009, 03:44 PM   #57 (permalink)
consaka
Active Learning - '93 Chevy Suburban Silverado
90 day: 10.67 mpg (US)
Originally Posted by dcb View Post
I don't know that you will have to amplify it with electronics anyway. I don't have any real experience with halls, but my understanding is that you just need to get enough magentism to the hall that it can switch on and off and make a signal for the guino, weather it is in peak or hold current levels.
Ok obviously I have been unable to make it clear how this type of sensor works. It is not a wheel speed sensor or a cam sensor signal. This doesn't get switched so to speak it just puts out a voltage relative to the current running through it. It is used to power meters that measure current. Thanks for trying to help. Ill figure it out..
