Old 04-23-2009, 04:19 PM   #81 (permalink)
ConnClark
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
Originally Posted by Piwoslaw View Post
In my diesel I start to feel the turbo in the 2100-2400 rpm range, but I hardly ever get into that range (never when ecodriving). I doubt whether the turbo helps in the 1400-1800 rpm range?
Hmm, maybe it's about time I unblocked it first? Then I'll see if it needs cleaning. If only I could find the time to make a temperature-controled grill block, then I wouldn't be worried about how much to (un)block depending on the weather.
Please unblock your intercooler. Your car will use less fuel and you will generate far less NOx and your engine will last longer.
A warm air intake does nothing good on a diesel.
http://ecomodder.com/forum/showthrea...html#post94488
