Originally Posted by ConnClark
Be careful trying to heat the fuel with a mechanical injection pump. Heating the fuel makes it more compressible which effects injection timing.
[b]The best way to get a higher efficiency with a diesel is to cram more air into the cylinders. This allows more fuel energy to go into heating the combustion gasses and less heat transferred to the engine block. Cooler intake air also helps for the same reason.[b]
If you take the route tas suggested and lie to your ECU about the amount of air by putting a leak in the line(which you could also do by placing a small butterfly valve with a servo on so you could vary it as you chose) then you should turn all the frontal area of your ride into a mesh covered ram scoop. It will lighten the load on the turbo allowing it to approach free-wheel speeds of 150K rpm or maximum boost at lowest possible temperatures at a lower engine rpm(takes less exhaust gases to turn the turbo if it has to do less work to turn).
