Old 04-23-2009, 11:47 PM   #11 (permalink)
theunchosen
The only issue I could forsee there would be the drive train would probably not much care for that. It would have to run a compression without having an expansion cycle to power it. You would also have to pump air through the other two cylinders even if they stopped injecting. IF you disconnected them from the crank thats different but way more complicated.
