Old 04-25-2009, 11:42 PM   #13 (permalink)
Big Dave
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
The commercially available diesel engines are pretty well sorted out from an economy standpoint. I, too have tried and gotten only trivial improvements.
Diesel vehicles can get better MPG with gearing changes. Diesel vehicle have to use the same gearing used for gas engines because of economics of scale.
Erni'e TDI Beetle uses a 3.89:1 ratio, but the TDI is very torquey and could easily push something in the range of 2.93 or 3.08 and such ratios will greatly improve MPG, particularly in conjunction with aerodynamic improvements.
If you think you can improve MPG with engine mods, you are kidding yourself.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
