Old 04-27-2009, 01:20 AM   #13 (permalink)
rkcarguy
Try using a water injection system with your lean burn. I've been doing some research and found that it can replace approx 10-12% of the fuel and may also allow you to push lean burn leaner. An added bonus is that it should reduce NOx emissions as well.
If your looking a the typical honda lean burn engine math says you'll want about 16cc/min of water injection, and it will have to be triggered by lean burn engaging via a relay or something. It's my lastest brainstorm to try and get more out of the lean burn setup.
