Originally Posted by MetroMPG
Nice!
How did the warm weather change things? (You posted about the grille block, but not the MPG!)
Metro,
The weather settled down a little today (57 degrees) and on my 11 mile commute to work I was up to temp. in about 3 minutes (warmup to temp was 6-7 mins stock and under 5 mins with first grill block...so that's an improvement). SGII reported 62 mpg on the commute (which is probably about 63-63.5 actual based on my current SGII setup and what I have seen during the 275 miles on this tank comparing to in-car stock instrumentation). Max temp was 191 degrees on the commute.
Supposed to be 91 degrees tomorrow!
