Old 04-27-2009, 02:52 PM   #1 (permalink)
don-vee
Mechanic of DOOM
don-vee's Avatar
Send a message via AIM to don-vee
The Eco-Brick! aka my 80 Dodge van
So, I went and got myself a sweet deal on an '80 Dodge van. Runs good, Slant 6, auto, short wheelbase, pretty basic. I needed a van for work, so I couldn't pass up this deal for $200. So, now the work begins.
I am going to try to squeeze as much MPG as I can from this thing without hacking chunks off with a sawzall. I am currently getting about 16-17mpg, and that's with me buying it and doing nothing. It sat for a year, so there's definitely some tune-up to do on it.
Here's the ideas I have, most of it I will be working with parts I have stowed away. I didn't want to go too insane with the spendy stuff, but maybe some of you can suggest other things I could be doing:
Give the ol' 6 a good tuneup
Replace the 1bbl intake and carb with a 2bbl with small econo primary
Hotter ignition, probably a Mallory Voltmaster with a Mopar orange box ICU
Header, 2 1/2 inch single exhaust into a Borla stainless hi-flow muffler
Electric fan (cut down on engine drag, improve cooling)
Lose the vacuum pump, install a vacuum reservoir instead
Trans cooler and shift kit
Slightly taller tires
Balance the driveshaft
Lighten the load a bit by removing the heavy plush home carpeting everywhere
I'm hoping to scratch 20mpg. I think it's doable. Anyone else deal with Slant sixes? Anything else I should think about? I realized I only scratched the surface with things I could do, but I'm trying to keep it simple and cheap for now.
