Running E85 in a '94 Acura (see signature). All I did was install injectors with an 18% greater flow rate. Run 3000+ miles with no issues except harder starting when it's below 20 degrees outside. I'm currently beating the EPA rating gasoline rating for my vehicle. If you take into account that E85 is 15-20% cheaper it adds up pretty nicely.
I plan on advancing the cam and ignition a few degrees. Should give me even better mileage. The nice thing about E85 is that it's 105 octane, so detonation is much less of an issue.
E85 ~$3.17/gal.
