Old 04-27-2009, 04:33 PM   #5 (permalink)
theunchosen
If you are in for it Belly pan is superior because it does not present as much frontal area for the same effect.
Lowering is just an added bonus. The lower the car is the more overlap of frontal area between the tires and the car(less tire sees the air) as well as it decreases the amount of air able to get under the car and cause havoc.
