I would worry more about your charger then your controller, if you try to drive and charge at the same time, but either way I think it will all be fine, you have the battery pack as the buffer.
If you are talking about a pusher trailer... then I would not do that with the motorcycle, to unstable! yes, it could be done, I'm sure but there are alot of things that could go wrong as well.
I have also thought about making a simple battery trailer with extra batteries, this would work for any electric vehicle and make the electric motorcycle alot more fun for short trips as you could leave it home and have the cycle be lighter weight, or make a really small light weigh electric motorcycle, or moped even and have all your batteries in the trailer.
