another gear(or swapping out your 4th and 5th is possible, trading 4rth for your 5th and moving 5th up a size) would allow you greater speed at lower RPM. If you spend alot of time on the highway at moderately high rpm(2500+) you will see an advantage otherwise you might lose out some as you will have to push one gear further into the rpm range to make the hop.
