I think vtec-e was right, you'd get somewhere from 3-5 mpg depending on how much turning you do. . .(if you drive a straight line the system doesn't have to work very hard). If you are going to go ahead and do this you may want to consider looping the belt from the other side off the AC. You'll save about as much in a full AC delete, but removing the belt gets you almost all the way to a full delete's savings.
