Old 04-28-2009, 01:08 PM   #13 (permalink)
Daox
The rear angle looks to be roughly 14°. There is definitely a curvature to it though.
The picture doesn't look perfectly level though either. The front end is slightly higher than the back end (referencing the trim piece on the door). But, its only about half a degree. So, the rear taper is probably closer to 13.5°.
