Originally Posted by Bullockracing
Look at the mods list (top of page), but I came up with a few cheapies for you:
1. max the inflation on the sidewall of your tires - 75 cents at the air pump
For this, I have always wondered, what is usually considered a safe inflation? A lot of you guys put your tire pressure up to 60 psi. I wouldnt think that that is what the tire is supposed to have. The max tire pressure as listed by the manufacturer is 36psi for my tires. How much above that can I go safetly? I am sure you guys have played with tire pressure quite a bit so any insight would be helpful.
