Old 04-28-2009, 06:48 PM   #31 (permalink)
theunchosen
even if we jump to co2 efficiency EV wins. . . unless you can convert crude to gas magically it always will.
It takes 138 kwhr to convert 5 gallons. Half of that power comes from the same coal to get you 66 kwhr of electricity. So you can have 138 kwhr that you can convert into essentially 82.8 kwhr or you can have 5 gallons that convert to less than 69 kwhr of useable work. 5 gallons yields 110 lbs of CO2 plus 66 kwhr of Coal CO2 plus more than double the CO2 the coal plant released from the refining process itself, while the electric only drops 85 kwhr of coal CO2 to produce more useable work.
Come on this is a no brainer. EV stomps gas all the way.
