Originally Posted by nubie
Most transmissions do have a pilot bearing, but not VW FWD transmissions. It is entertaining because there is a pushrod that travels through the mainshaft on the trans to release the clutch. The clutch is backwards so the pressure plate is bolted to the crank and the flywheel is put on over the friction disk.
Germans are sorta weird, but I think that clutch was only used from 1975-6 through 1999.
Very True....but man! oh man! That's THE EASIEST throw-out bearing change you can EVER do..... pop a 3 inch cap, loosen the clutch cable, pull it out with your fingers and slap the new one in place! No tools other than a screwdriver to pry the cap off! Hahahahaha!
Wherewolf
EDIT: OK OK Enough! Back to the controller
