Originally Posted by Ryland
Yes, because it's a modified motorcycle, or so you are telling them, double check this with your own research in your state statutes and you might check in to the guidelines for hobbyist plates in your state, as it might be a good idea to get that type of plate so cops will have less of an issue with it, as they are normally put on vehicles that are modified, that way you will be fallowing as many rules as possible.
Would you happen to be able to point me to the language in Wisconsin's laws that describes this process? Have you built and registered a car based RT?
Brian
