Dead Band in Prius
Pic is of my commute to work of 11 miles and additional 4 miles out of the way to go to the bank. The low bar in the 20-25 minute range is a result of sitting in the drive up window to process my transaction. It should be noted my mpg did not drop in that 5 minute window because I was over min temp and gas engine did not need to run to power up to temp. For some reason the Prius in-car mpg still factors stopped idle time as 0.0 mpg (even though not using any fuel), hence, the lower mpg bar in that 5 minute span.
I've been tinkering with dead band, EV mode and neutral coast and saw some good numbers today (in 70 degree weather). This 15.5 mile trip was 66.4 on the SGII and I have my in-car mpg up to 61.7 (up from 56.9 mpg in-car at this point in my last tank). SGII is reporting approx. 4 mpg higher than last tank.
I took a vid of my driving in dead band...what's the best way to post it?
