Old 05-01-2009, 04:32 PM   #3 (permalink)
stevet47
Eco Dreamer
Versa - '08 Nissan Versa SL Hatchback
Actually there are 2 ways to do sticky weights. The first is what TomO is referring to, when then just put the weight centered on the inside of the rim. Most alloys use 2 spots for sticky weights, weight on the inside of the rim, and weight just behind the spokes.
You'd be just fine going with the 2nd option.
